I no send messages from my appear f28 - Washing Machines
F28 error code
I have a LG washer and dryer and mine get a PF code for power failure. I don't know if that's helpful or not. Contact the manufacturer for information on what the different codes mean. You can also look at the booklets that came with your machine. A lot of times, manufacturers will have the user manual online at their site.
Dec 10, 2013 | Kenmore Elite HE5t Washer
Ok I had my pump replaced a few weeks ago but now I am getting the sud and f35 and f28 messages. What shouli do anjow much is the switch?
Try this one to remove the error display f35 and f28
Press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
Jun 03, 2011 | Whirlpool Washing Machines
F 28 error code comes on
Greetings,
The f28 is a communication error...they usually happen at the right side of the drain pump where the wires go in there is a flip top cover..if its up, just push it back down and that should do it...also, if the service panel at the bottom is off..there is a panel switch that trips until the panel is put back on..this can cause an f28 as well...
If neither of these do it..just make sure all the connections are tight, again the is a communication error between boards and even the main control could be defective.
Bruce Denton
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When sending an email, the system has suddenly asked the following question:- To stop spammers, we sometimes ask you to enter characters. How can I remove this message and continue to send emails
Heya
This message will appear every once in a while just to check if its an auto generated message or not because once your account is hacked they keep on sending spam emails to your friends or the email address which are saved in your address book.
This message is for your own safety so i would suggest you to do enter the characters whenever it appears.Anyways it will appear after every 40 to 50 emails you send.
Thanks
Dec 09, 2010 | Computers & Internet
My washer stopped and was flashing F21 (drainage issue) so I called a plumber. He checked the hoses and removed the panel and cleaned the drain trap. It didn't fix the problem it's still won't drain. It...
The SUD message relates to overdose of detergent detected during the Wash Cycle.
This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked. this seems to be the reason as to why your unit is not fixed even after trying to solve F21......
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Good luck
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F28 error message
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 18, 2009 | Kenmore 44102 Front Load Washer
My friend is on hotmail and they appear offline anytime
You can be logged into hotmail messenger and choose how you want to appear to your contacts. The 'status' optains range from:
Available
Busy
Away
Appear offline
Although you may choose to appear offline, you are still logged in can send and recieve messages. All it does is discourage contacts from sending you messages when you are busy.
Jun 15, 2009 | Computers & Internet
The paper keeps jamming in my konica photocopier and the following message appears F28 3 Contact service department
F28 High voltage leak. (coronas)
The corona wires are arcing, it is located directly under the drum a unit with three thin wires. the end blocks go bad and it arcs causing jams and copy quality problems, replace the corona ***'y.
Other cause may be the High voltage unit for the coronas itself
check this site for the price
precisionroller.com
Dec 01, 2008 | Office Equipment & Supplies
F28 error
Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
