Question about MSI Computers & Internet
Msi g41 p26 mothrboard swthing problem solution
2 Suggested Answers
SOURCE:
  • 129 Answers
SOURCE: I HAVE MSI G41 Motherboard G41M-P26. MY PC
try sir first to scan your pc with a reliable and full operation anti virus, restarting pc usually is infected by virus.
Posted on Jul 11, 2011
MSI G41M-P26 jpwr2? if i disconnect it no power. if i connect it there is a power but no display.
You don't give enough information. You need to decide if motherboard is starting up - and you can hear hard disk(s) running and accessing data, or if everything is totally dead.
If the former the lack of a display could be a fault with your graphics card.
You need to see if the power supply is running, look and see if its fan is going and then listen to see if hard disk motor is running. If these are dead try a replacement Power Supply.
If you get some text or graphics on the screen when you first turn on, and before screen goes blank, that suggests it is running and the blank screen can be due to a software problem.
If you need more help, supply more info about the fault.
Cheers.
May 16, 2014 | MSI G41m-p26 Desktop Motherboard - Intel...
Boot problems
SOURCE:No boot No video on new built pc with a msi motherboard a55m-p33 amd, three beeps at start up.
Hello here is the homepage:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Driver&os=Win8%2064
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Tree beeps means you have a ram module failure, or not inserted correctly.
This mainboard uses DDR3 ram, up to 16 gb.
Try to start with only one module at the time.
Try also to check the manual:
http://www.msi.com/product/mb/A55M-P33.html#/?div=Manual
Jan 14, 2014 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
My Msi G41 TM-P33 mainboard is cann't run probability. It run first step, but don't run if i save bios setting.
Hello download the manual here:
http://www.msi.com/product/mb/G41TM-P33.html#/?div=Manual
Please unzip the file, and adobe reader is needed to read the content.
Try to enter the bios, and load default settings.
Select the boot option for the drive.
First boot device: dvd drive.
Second the harddrive.
Save the settings you have made, and leave the bios.
Good luck
Dec 24, 2012 | Intel Motherboard
Msi g41m-p26 won start (no power)
The most likely solution is to replace any Capacitors that have blown in the onboard power circuit. Look for a Capacitor that has got a very bulging top in the region of the power connector.
Dec 05, 2012 | Computers & Internet
How to reset bios on a msi g41m-p26
on the board is a jumper right above the pci slot (blue) with the pc powered off, move the jumper to pins 2 and 3, then wait 5 seconds, then move it back to 1 and 2. your bios is now reset :)
Jan 01, 2012 | Computers & Internet
Last night this computer works very well but today morning no signal,no beeping, all dead. My this computer use MSI G41M-p23 motherboard.
1.Release the MEMORY MODULE ( RAM )
2.Cleanup the connector Module with a dry tissue or white clean paper
3.Put it back on
Note : If you have double RAM >> try using patially...
akee_akee@live.com
Aug 16, 2011 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
G41tm-e43 + windows 7:
just install ur orignal window 7 driver for ur motherboard
http://www.msi.com/index.php?func=proddesc&prod_no=1791
follow this link
Mar 06, 2010 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Computers & Internet Logo
41 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
