Question about OTC ACR201-G (00CSPP000122) 802.11b/g Wireless Bridge
Need help I need to know how to access the web GUI on the OTC ACR201-G. I had to reset my device, and now I can't find the manual on how to access the device. Please help!!!
  • 1 more comment
  • Chad Knepp
    Chad Knepp Nov 30, 2007
    Thanks, but I am fully aware of how to access my router and config it. I have been doing this for awhile. I am looking SPECIFICALLY for information on the OTC wireless device I have mentioned. If you are not familiar with these products then this post does not apply. They have a specific config, because it is basically a network adapter that is used with high grade printers to create a wireless print server. These devices can also be connected through a regular RJ45 jack, and be used as a wireless connection device. Thus, its configuration page is masked and you have to know the default that OTC/Pegasus uses. And No, its not the generic Linksys (or other popular branded routers) address. And I have the Nmap, and have already tried that along with a few others to attempt to get the default page, and still have been unable to find it.
    I am looking for someone who HAS SPECIFIC KNOWLEDGE OF THIS UNIT. Thanks for your attempt though.
  • Chad Knepp
    Yes, I have tried everything in the book. TRUST ME, I am have been doing networking for the last 10 years. These devices are just ass-backwards of everything. I used to have a pdf doc that had the info in it that i had got from OTC website, but it appears that OTC was bought out by Pegasus and there is no support site for Pegasus. Hence why I posted on here. Thanks for trying, but as I said before, unless you are familiar with this device, you won't be able to assist me.
    Have a nice day.
  • pcdino Jan 31, 2008
    have same problem. Solution number 2 posted by "guest" seems to offer some guidance but appears incomplete.
    further assistance would be appreciated
Included with the Wireless Print Adapter
þ ACR-201-G 802.11g Wireless Adapter
þ 5V AC adapter
þ White straight-through UTP Cat5 cable
þ CD containing technical manual
þ Velcro mounting pad
Step 1: Connect the power supply
A. Connect the 5V AC adapter output to the DC
input on the bottom of the Wireless Adapter.
The Wireless Print Adapter is preconfigured to
work with wireless networks that are
broadcasting the SSID and do not have
security encryption enabled. If your network
is configured in this manner, go to Step 3 now.
Step 2: Configure the Wireless Adapter
A. Use the white straight-through Cat5 cable
to temporarily connect the Wireless Adapter to
your computer’s network port.
B. Verify the orange LED labeled “Link” is
blinking regularly.
C. Open a Web browser and enter in the
location field When
prompted, enter “admin” as the user name and
“public” as the password.
Note: The computer must have its network card
configured for the same subnet as above to
access the device web page. Refer to the
technical manual on the CD for more details
and technical explanations.
D. Verify the SSID and WEP key or WPA key
match that of the access point in your area.
Refer to the technical manual on the CD for
more details and technical explanations.
E. Go to the Link Info tab. Check that Link
Quality and Signal Strength show signal levels.
This verifies the Wireless Adapter is configured
properly and an access point is in range.
F. Disconnect the white straight-through Cat5
cable from your computer
Posted on Jan 25, 2008
    Problem Solver:
  • 16 Answers
Try typing into your browser. That is usually the default address used by most routers and such. If that does not work then find an open source network scanner like Nmap and run it to determine the IP and then type it into your web browser. Word of caution these tools are for experts.
Posted on Nov 30, 2007
  • Ron Malouin Nov 30, 2007
    Ok, you have most likely hooked it up via the RJ45 to you CAT5 network and gone to your router's DHCP table and looked to see if you can see the assigned IP. Anyway good luck.
I enabled mac filtering on my tl-wa521og, and i cannot connect to my router's lan and even wifi.... its so hard for me reset the router because it was already installed in the tower, is there any way to...
Yes you can.
1-Login the Web-based Interface ( or or of your wireless access point or extender.
2-go to the settings windows and find the reset tab (usually "reset to factory default)
3-Your are done
Mar 11, 2014 | TP-LINK Computers & Internet
The gui setup wizard is not popping up/opening and i cannot access
If you're using Windows, plug the ASUS device in via wired (ethernet). Hit Start, then type in CMD, then type in ipconfig. Look for wired local area connection. Do you see That's probably the ASUS. Now, type that in your browser. Voila, the GUI should pop up. It worked for me.
Oct 10, 2012 | ASUS EA-N66 Dual-Band Wireless-N900...
I'm trying to ad a mac ipad to my belkin54g router.. i believe the router is locked to stop access. how do i unlock the router
Are you able to access the configuration utility inside the router or are you asking how to do a hard reset?
Mar 03, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Connects and drops when using wpa will not stay connected has great signal
Please check for the wireless signal strength of the wireless router.
Try to access the internet in an area where the signal is excellent.
Oct 30, 2010 | OTC ACR201-G (00CSPP000122) 802.11b/g...
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Factory reset d301+
i have the cd that would allow you to factory reset the device once installed reply to this i will sent you the executable ..
Jul 07, 2010 | D-Link DP 301P (DP-301P) Print Server
No signal for wireless. Trying to get onto Ipod touch and says no wi-fi. Lights are blinking on router. The #1 the middle button is flashing and the 2 next to it.
1.You will need to add the device to the router in the wireless access. this is done by MAC(Media Access Control) address of the device to be used.
This done be logging on to the web gui using or ( consult your user manual for the proper IP address.
2. check your instruction set for the device to see how to link it with a router ( should be in your installation instruction)
3. On the PC go to the command line and type "cmd" this will bring you to the DOS prompt the type at the prompt ipconfig /all >>> this will let you know all device that are connected to the router.
Jun 25, 2010 | Linksys WRT160N Wireless Router
Hi..i have a linksys voip 2pt adapter. My phone set keeps on going silent (i hear no tone). I tried going to the config menu but thewebpage never opens and it keeps on prompting me for user and pass (which...
If you are losing audio during a call, there is almost certainly a configuration issue. You are going to have to access the web GUI and correct the incorrect settings. If you plug an analog phone into one of the ports and dial ****, you will hear "configuration menu". Enter 73738#. It will tell you to enter 1 to confirm. Press 1. The unit will restart and you will be able to access the web utility using the default login/password. Do this only if you know what your settings need to be and you are capable of provisioning the device. This procedure will return the device to its factory default configuration. This will work assuming you have an unlocked voip adapter. If yours is locked by a service provider, there is a good chance you will not be able to default the adapter using this method.
May 28, 2010 | Linksys IP TELEPHONY - VOIP RTR W/ 2 PHONE...
Cannot access the internal webpage. How to reset?
there is a small button usually @ the back of the router ... press it with a pen or pin for like 2 minutes and u would see the light flashing ... the router has come to factory default.
Jan 10, 2010 | OTC ACR201-G (00CSPP000122) 802.11b/g...
Sonicwall Safe mode Problem
How do I access the SafeMode menu?
In emergency situations, you can access the SafeMode menu by holding in the Reset button on the back
of the TZ 180 (it’s the small pinhole button located to the left of the Console port) for 12-14 seconds until
the ‘Test’ light begins flashing yellow. When the SonicWALL is booted into the SafeMode menu, assign a
workstation a temporary IP address of and attach it to a LAN interface on the TZ 180
Then, using a modern web browser (Microsoft IE6.x, Mozilla 1.4+), access the special SafeMode GUI
using the device’s default IP address of You will be able to boot the device using a
previously saved image, or you can upload a new version of firmware with the ‘Upload New Firmware’
Apr 07, 2009 | SonicWALL TZ 170 Firewall
OTC ACR201-G (00CSPP000122) 802.11b/g Wireless Bridge Logo
240 people viewed this question
Top OTC Computers & Internet Experts
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you an OTC Computer and Internet Expert? Answer questions, earn points and help others
