Heating & Cooling Logo
Jo-anne Matte Posted on Oct 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sharp heating and air conditioning system and would like to know if my air exchanger should be on at the same time! Thank you!
Marvin
Level 3:
Top Expert:
  • Sharp Master 85,242 Answers
  • Posted on Oct 11, 2018
Marvin
Sharp Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024802
Points
266281
That is a personnel decision. The setting is to introduce fresh outside air, in the other setting it recirculates the air from the inside of the house, this is more efficient,
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Sep 05, 2008
SOURCE: honda civic air conditioning
check the switch continuety /a short somwhere?
Anonymous
  • 71 Answers
  • Posted on Oct 10, 2008
SOURCE: Not getting any heat from my Automatic air conditioning and heating heating system
Could be a couple of things. The first thing that I would check would be the coolant level in the radiator, if that is low it can cause the heater not to blow hot air. The second thing I would find out is if the control to change from cold to hot is actually working? ( if it is a manual slider then the cable might have come off of the control behind the dash...if it is digital then there may be a wire off?) The third thing it might be is that your Heater Core went bad and will need to replaced. As I said above, I would check the coolant level first and go from there. Hope it helps!
Anonymous
  • 3 Answers
  • Posted on Feb 16, 2009
SOURCE: heating and air conditioning system
when your on defrost the ac will automatically turn on if its not on defrost the ac shouldn't come on thanks
Anonymous
  • Posted on May 23, 2010
SOURCE: My heat and air condition system are not lighting ...
You need to set the fan control knob to #2 position and pull the knob off. Get a pair of needle nose pliers and extract the bulb. Take to the auto store and get a replacement.
bharat patel
  • 268 Answers
  • Posted on Aug 02, 2010
SOURCE: air conditioning / heating system fan works on
Fan resister circute/switch needs to be replaced. Not expensive. Buy from dealer.
2answers
If radiator in air conditioner is dirty will that cause problems
Yes indeed. Air conditioning is all about transfer of heat. Radiators exchange heat. AC systems actually have two radiators. One is the evaporator coil which absorbs heat from the conditioned space (to cool inside your home.). The other is the condenser coil which releases the heat to outside. If either one of these heat exchangers have a problem, then the entire Air Conditioning system has a problem.
6answers
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
tip
KNOWING ABOUT CONDENSER
What is a condenser?
Is a device or unit used to condense vapor into liquid. A condenser is simply one component of an air conditioner. Whether you have an outdoor air conditioner or a window unit air conditioner your air conditioner contains a condenser.
Condensers are used in outdoor air conditioning systems as well as heat pump systems. Condensers in an air conditioning unit have very few controls. They will have an on and off switch. Occasionally these air conditioners will also have a brown out option. This option shuts down the compressor when the electrical current is low.
A condenser is simply a heat exchanger. It compresses refrigerants into a hot gas to then condense them into a liquid. A condenser is a major component in a air conditioning or heat pump unit. It moves air across the coils to facilitate the transfer of heat.
In a heat pump unit the condenser has a few more features. It will have a reverse valve that allows the unit to switch back and forth between air conditioning and heating. Even when the unit is heating, it uses the condenser for defrosting the coils. If the coils become layered with frost it will effect the units effectiveness this is defrosted when the reverse valve switches to air conditioning mode to move the hot gases through the coils melting the built up ice. It will automatically switch back to heating mode once the ice is cleared to once again heat the home.
To keep your unit in good operating condition it is vital to keep the area around the condenser clear of all debris as well as keeping the filter clear of dust and dirt. A clean machine makes a happy machine. A happy machine will keep you cool during the summer months and warm during the cold months. It is suggested to change the units filters when they become dirty, depending on your area and conditions near your home this may be as often as once a month or as seldom as every 3 to 6 months. You will have to pay close attention to your units needs to decide the right time to change or clean your unit’s filters.
It is very important no matter what type of unit you have to prevent the blockage of the condenser. If the condenser becomes block it can effect the units efficiency or even cause the until to completely fail. For this reason it is one of the most important components of a cooling or heating system. A condenser allows the maximum airflow to the unit.
Keeping you condenser in good running condition will not only prolong the life of your heat or cooling system but also provide you with the most efficient heat and cooling system saving you money on heat and cooling.www.victorwod1234.blogspot.com
on Apr 08, 2010 • Heating & Cooling
tip
Heat Air Exchanger for Heat Recovery
An air-to-air exchanger is used to recover heating or cooling and to improve the air quality of the building that it serves. Typically an air exchanger has two fans, one blowing air into the house and one blowing air out of the house. In the winter time the one fan brings the outdoor cool air through the core warming it with the warm stale air you are exhausting. In the summer time the warm air from the outside will be cooled as it enters through the core to save on your cooling.
Air exchangers often are used to perform many functions such as reducing air contamination, heating or cooling air entering the building, and humidifying or dehumidifying air before it enters the building. Air to air heat exchangers or heat recovery ventilators, are used to provide a balanced flow of air into and out of a building. Ultimately an air exchangers main function is to switch the stale inside air with fresh outside air while exchanging the heat or cool in the process.
There is some controversy about the savings of exchangers. Not only does it require electricity to run the air exchanger, but the air the exchanger brings into your house must be brought up to temperature. This may require that more electric is used to cool your building or that more fuel is also required for heating.
The amount of air that these air exchangers bring into a home may vary depending on how the system has been installed. The codes in many places require a minimum amount of air to be exchanged. Check with your codes official to see what the requirements are for you.
Air exchangers can be a very good thing for many buildings. Especially those that are very large and typically have a lot of occupants with little natural air exchange from doors or windows being opened. However they are also a health hazard if they are not serviced
All air heat exchangers will require regular maintenance. The problem is that this is almost never performed by homeowners, and unless they know about the exchanger it is often overlooked by contractors during service calls. The real problem is that clogged, air-to-air exchangers can make the indoor air significantly worse than it would be without the system installed at all. If you have a home that already has a heat air exchanger, make sure that you keep it very well maintained or disconnect it.
Many air exchangers are controlled simply by on and off switches, but in some applications where the removal of humidity is required, then a humidistat can be used to turn the machine on and off to achieve the humidity level that you want. In cases where there may be a lot of humidity the air exchanger may not be enough to solve the problem. Other devices may be needed to lower the humidity to the level that you want.
on Dec 24, 2009 • Heating & Cooling
On a water cooled scotsman ice machine, should the water be running out of drain line contiuously as its making ice? be cause it just runs all the damn time and thats a huge water bill ...
On a water-cooled system, by design the heat from the machine is being transferred to running water that carries the heat away. Some installations pump this "waste" water to a heat-exchanger or cooling tower (typically on a rooftop), where the heat is transferred again, this time to the air. The water with the heat removed is then recycled back to the machine, where the process is repeated continuously. There is thus no "wasted" water.
If your cooling water is just running down the drain, that's a terrible waste of water and money. Try to find a way of recycling the water by removing the heat and re-using it. Think of ways to use the "free" heat in the water.
Alternatively, buy a proper rooftop heat exchanger and pump the water through it, or, get an old car radiator or air conditioning condenser and a decent blower, and make your own.
Remember that your machine needs constant cool water in order to avoid overheating the system.
2helpful
WHY DOES MY RADIATOR FAN COMES ON ONLY WHEN MY AC IS ON ON MY 88 TOYOTA COROLLA
it is generally because the air con heat exchanger has to be cooled in order for your air con to work correctly and cool the interior of your car.
The air conditioning utilises a gas by the name of freon. This gas is pumped around the air con system by a compressor. The gas, going through the aircon cooler or heat exchanger, starts to cool down. Depending on the system layout, the gas is forced through a very small aperture situated after the cooler. It reverts to a liquid, passes through the matrix in the car, a fan blows the interior air of the car through the matrix. The fluid picks up the heat, and cooler air exits the matrix and, (hopefully) cools the interior of the car. This endless cycle is repeated as long as the air con is powered on.
Hope this brief description will suffice.
Heat does not come out passenger side of the car but comes out drivers side
There is a blend door problem.
prev.gif next.gif HEATING AND AIR CONDITIONING Refer to Section 1 for discharging and charging of the air conditioning system. The heating system provides heating, ventilation and defrosting for the windshield and side windows. The heater core is a heat exchanger supplied with coolant from the engine cooling system. Temperature is controlled by the temperature valve which moves an air door that directs air flow through the heater core for more heat or bypasses the heater core for less heat. Vacuum actuators control the mode doors which direct air flow to the outlet ducts. The mode selector on the control panel directs engine vacuum to the actuators. The position of the mode doors determines whether air flows from the floor, panel, defrost or panel and defrost ducts (bi-level mode).
Honda civic air conditioning
Changing filter
The filter should be located in the return air flow duct either inside the furnace or in the ductwork
you should have it inspected by a service contractor
as far as when it should be replaced depends on the condition of the heat exchanger and overall condition of the rest of the parts it could start to nickel and dime you
Top Sharp Heating & Cooling Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Ngoro
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
