Firearms Logo
c
charles horak Posted on Oct 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hopkins and allen riflesingle shot .22 cal. serial no. 822.what is the of manufacture?
Terry
Level 3:
  • Master 11,377 Answers
  • Posted on Oct 13, 2018
Terry
Master
Level 3:
Answers
11377
Questions
Helped
4625323
Points
152765
2 Related Answers
strech3030us
Strech
  • 1562 Answers
  • Posted on Feb 20, 2014
SOURCE: i have a remington 22 cal model 12 serial number 187554 and would like to know the manufacture date
Introduction Year:1909
Year Discontinued:1936
Remingtons manufactured between 1921 and 1972 have a code located on the left side of the barrel near the frame that identifies the year and month of manufacture.
If yours is between 1921 and 1936, it should have two letters, one for month, and one for year.
If it doesn't have this code, it was made between 1909 and 1920.
REMINGTON Customer Service (1-800-243-9700 & follow the prompts) will look up your serial number and verify the age of your firearm.
Just to give some scope, serial number 757132 was 1929, about 569578 after yours.
Duff Howell
  • 403 Answers
  • Posted on Dec 03, 2015
SOURCE: single shot looks brass black powder only hopkins and allen arms cor N.J. U.S.A S.Marco cal.58 #2279. WHAT IS IT WORTH?
Good afternoon Jay.
I found a couple .58 Cal Lyman Muzzle loaders for sale here:
Muzzleloading Rifles Modern Replica Percussion For Sale that were posted for $600. A H&A .22 rifle here
FALLING BLOCK 22 RIFLE was listing for $250 Wish I could get closer than that, but listings on H&A tend more toward shotguns and pistols, and have prices anywhere from $30 'wall guns' to $500+
Cheers
D
2answers
When was manufactured my Marlin Golden 39A cal.22 Serie# T12221
Check this out my friend, you'll know after this! Any more?'s just ask! Have an awesome day!
Mar 16, 2019 • Firearms
I have a Iver Johnson 22 caliber double action revolver, 8 shot cylinder, 2.75 in barrel. It’s a model 66. Serial number k12190. Can you give me information on this model.
You already have all the information model and serial number so what else are you looking for? A good source for numbers manufactured and dates is the Blue Book of Firearms Values. You can have any local gun dealer or gunsmith look this up for you.
Jan 17, 2019 • Firearms
I have an Iver Johnson Cadet Model: 55S-A. 32 cal. 2 1/2 in BBL. 5 shots Serial No B27690. I would like to know more about the gun.
The Iver Johnson Cadet was offered as (the basic gun) as the Model 55 Target, and the 55A then the 55S Cadet and the 55S-A Cadet. The "parent" is discribed as: IVER JOHNSON MODEL 55 TARGET,Revolver,double-action,22LR,8-shot,4 1/2",6" bbls and 10 3/4"(6") 9 1/4"(4 1/2") over all length weight 24 oz.(4 1/2") 26os(6"); large frame,pull pin cylinder release with flash control front rim; recessed cylinder chambers;fixed sights,oversized molded one piece Tenite plastic target type grips; Does not have the "hammer the Hammer'action,matte blue finish; After 1958 cylinder is fluted hard chrome lined barrel introduced in 1955; dropped from production in 1979..the .38 caliber offering is designated as the Model 55S-A which is the same as the above except that: it was offered in .22LR,.32 S&W and .38 S&W(this is NOT a .38S&W Special) and as an 8-shot in .22, as a 5-shot in both .32 and .38. it is 7 1/2" oal w/ loading gate on the Right side AFter 1974/1975 this model is called"I J Cadet it was introduced in 1961 and dropped in 1979 Values: Vgood=$110..Good=$85 and Fair=$75. This data is from the Gun Digest Book of Modern Gun Values and more detailed Iver Johnson histroy can be had from www.gunshowbooks.com..check out Bill Goforth's Iver Johnson Arms&Cycle Works Firearms 1871-1993..Bill also frequents these forums and he along with Jim Hauff will likely correct any misinformation I may heve relayed as well as correct any ommisions.
Oct 04, 2018 • Firearms
I have a Hopkins and Allen model 1801 with sn b1146. What year was it made?
Try the Blue Book Of Firearms Values. Most gun stores have a copy.
Sep 16, 2018 • Firearms
I have a small frame 7 shot 22 Cal. break top H&R revolver. I was told my grandfather carried it in WWI. Serial# 371177. I would like to know the manufacture date and if it was an Army issue.
James
Decoding H&R serial numbers is not easy and it takes up quite a bit of the H&R book as different models usually have seperate serial number series. gererally speaking there were three types of serial number series.
Pre 1905 (1904 and before) which were more like batch numbers and usually ran from 1 to 99,999. on some models there was a different series every year.
Post 1904 (1905 to 1939) one single series starting at 1 and going into the middle 6 digits (some third model auto-ejecting revolvers have been observed with number in the 800,000 range.
Ift here does not look like there are any markings on the left side of the barrel other than the caliber this would be the premier model fitted with extra cost oversize grips and 6 inch barrel. during the same time (1925-1934)frame H&R offered this revolver as the H&R TARGET (aka model 766) the only difference was H&R Target was marked on the barrel. by the time the premier model was fitted with a longer barrel and oversize grips the cost was about the same for the two models. the offering of the H&R Target model was just another way to try to sell more revolver. factory serial numbers are not available for this model so i believe this revolver was manufactured before the H&R Target was introduced in 1924 (most likely 1920 to 1923)
below is information of both models.
H&R PREMER SECOND MODEL SMALL FRAME TOP BREAK R.F. & C.F. ----------1905-1941
Small fame double action top break revolver with double top post barrel latch; calibers and cylinder capacity, 22 rimfire-7 rounds, 32 S&W, 5 rounds; automatic cylinder stop; standard finish Nickel with case harden hammer and barrel latch; standard barrel length 3 inches, with 2, 4, 5 and 6 inches available as optional; HAS CALIBER MARKINGS ON LEFT SIDE OF BARREL WAS MANUFACTURED FOR SMOKELESS POWDER CARTRIDGE PRESSURES.
There has not been enough data gathered on serial number to try to come up with a serial number range for the different variations.
First Variation, model name & caliber marked on left side of barrel, patent dates 5-14-89, 4-2-95, 4-7-96---------------1905-Only
Second Variation, model name & caliber marked on left side of barrel, patent dates 4-2-95, 4-7-96-------------------1906-1908
Third Variation, caliber only marked on left side of barrel, patent date 10-8-95-------1909-1913
Fourth Variation, caliber only marked on left side of barrel, no patent date, state not spelled out in address (MASS)---------1914-1915
Fifth Variation, caliber only marked on left side of barrel same as 4th except different font used in barrel markings----------1914-1915
Sixth Variation, caliber only marked on left side of barrel. State name in barrel marking spelled out (MASSACHUSETTS)-----1916-1924
Seventh Variation, new grip frame, there is no step down for the grip panels to fit into-----1925-1942
After 1930 listed in catalogs as; PREMIER No. 30 .22 Rimfire 7 shot & PREMIER No. 35.32 S&W 5 shot
VALUE: 100%=$265 60%=$75 Add 10% premium for blue finish; 20% premium 4", 5" or 6" barrel; 20% premium for 22 rimfire caliber; 10% premium for 7th variation
If this is a top break it is a H&R Premier model manufactured in the 1924 to 1930 era or one of its variations. if it is a solid frame model it is a model 1906 or one of its variations manufactured in the 1932 to 1937 era. without a picture or knowning the exact markings i can't give you an exact model.
1940 and after letter codes used to denote year of manufacture. starting with A in 1940 and going to BC in 1986.
Caliber markings on the side of the barrel ALWAYS indicate 1905 or after manufacture. when H&R made the switch to smokeless powder in 1905 they started marking the caliber on the left side of the barrel of all their handguns. no caliber markings = black powder, caliber markings = smokeless powder.
Please keep in mind that H&R did not always obey their own rules and there are exception to every rule. during 1890 though 1904 H&R was manufacturing so many top break revolvers they starting using a letter code after 100,000 had been reached. these letter code were stamped along with the serial number on the bottom of the top strap (the cylinder had to be removed to see this location).
Hammerless Bicycle models (1899-1920). the caliber markings and 6 digit serial number indicate it is a second model and if in good condition it should be safe with modern ammo. the bicycle hammerless (small frame, 2 inch barrel) is serial numbered in the same series as the regular small frame hammerless model.
Pete
Apr 11, 2017 • Firearms
Top Firearms Experts
vince
jws1013
Kolbrun...
Are you a Firearm Expert? Answer questions, earn points and help others
