Question about Kenwood 12" 4-Ohm Single-Voice-Coil Subwoofer
Unsureness of wiring configurations.
Hello,i have 2 audiobahn alum 12" subs and would like to buy an amp to get the most out of them and a wiring diagram to assist,any advise would be greatly appreciated.
  • 45 Answers
Also- get a voltmeter to check the ohms on your speakers before hooking them up. If you want extra power, and your amp can handle it, you can wire the subs down or in parallel. This is where the voltmeter is needed. check your amps rating and match it closely. For instance if your amp can handle 2ohms mono. You would wire two (single voice coil) 4ohm subs in parallel, and connect that to the amp. But if you have dual voice coil subs you will need to wire the subs differently. For dual 2ohm subs each sub would first be wired (with a thick speaker wire). Take one positive pole on the sub and wire it to the negitive pole of the opposite voice coil. Which should leave a positive from one voice coil and a negitive from the other. With a dual 2ohm subs you will see 4ohms, and with dual 4ohm subs you will see 8ohms and so on. Once you have one sub done you need wire the two subs together and use the same procedure (as if each sub is a voice coil) to determine the overall load on the amp. Your amps Ohm rating will determine which way to wire your subs. Example- If you have dual 4ohm voice coils and your amp will handle a mono 1ohm load. It will put out much more power at 1ohm than if you wired them to a 8ohm load. In fact the power output is determined by resistance (ohms). Except a few amps like JL Audio, most amps will follw this rule. A 100 watt amp that is rated at 100 watts at 8ohms mono, and is capable of a 1/2 ohm mono load (very important). Will double it's output everytime you drop the ohm load in half. i.e.-
8ohms=100watts (all numbers are mono ratings)
I won my first SPL competition using this formula. I entered a 150x2watt amp class and wired my amp down to a 1/2ohm mono load thus making a 150x2 amp push 1200watts! (I used 2 - dual 2ohm voice coil 15" CV Strokers wired in parallel.)
PLEASE BE CAREFULL!!! there are only a few amps I know of that can do that and survive. The only other downfall (besides reliability, heat, and warranties) is there will be a corresponding drop in sound quality. This begins a whole other subject so I will just say this. This drop in sound quality is sometimes not noticed due to the nature of subwoofers (especially in cars). I hope this adds to the above info and further answers your question. For extra info please contact me @ thanx.
Posted on Mar 26, 2009
  • 709 Answers
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Posted on Nov 28, 2007
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
1 Answer trying to find a diagram on how to wire my subs down to 1 ohm..i have 2 12 in. Audiobahn alum12n..they are currently runnimg at 3 ohms on a hifonics 2500 watt 1 channel amp that only supports 1 2...
Hi, if you wire all voice coils in parallel, you will get down to 1.5 ohms. That is the lowest you can go with these 2 subs. Just hook the amps' positive to all 4 positive speaker terminals and the amp negative to all 4 speaker negative terminals. Please let me know if you have more questions, and thanks for using FixYa.
Mar 22, 2011 | AudioBahn Car Audio & Video
I have a pioneer 760watt model gm5100t amp and two audiobahn 12" subs and I would like to know how the wiring is configured from the amp to the subs as well as how the subs are wired since they are dual...
you bridge the inside + - and use the outside + -
then connect the outside + to the amp then connect the - to the + on the other sub then the - on the other sub to the amp just read this and do it slowly and you will get it then you only have to run the subs on a two channel amp
rate pls
Aug 14, 2010 | Pioneer GM-5300T Car Audio Amplifier
I need help hooking up a 12" alum audiobahn
check out and click on the tech support. then you while see some diagrams for subs, for different ways check it out it helped me out with my aw1508x being pushed by two a2300hcx
Mar 01, 2010 | AudioBahn AW1206T Car Subwoofer
No sound from sub
simply give it a 2 wire signal and you should hear something! if not then depress the cone lightly back and forth, if you hear alot of scratching/scraping sounds, prognosis in not good.
Sep 15, 2009 | AudioBahn AWES12P Car Subwoofer
I have a audiobahn a400t and im running 2-12''jh45 mtx jackhammers the speakers are wired in parallel stabel @ 2or1 ohm. the speakers are in a ported box. how do i run my wires to my hook these up right to...
Hello rattle822,
A pair of JH4512-04's can be wired to 2 ohms if the subs themselves are paralleled. There's only one voice coil and it's 4 ohm. If wired in series, the final impedance to the amp would be 8 ohms. They cannot be wired to 1 ohm.
In bridged mode, your 4-channel amp is only stable down to 4 ohms. You can bridge 2 of the channels to provide a relatively low 200 watts RMS X 2. The best power solution for your subs would be to bridge channels 1 and 2 and wire one sub to it. Likewise, bridge channels 3 and 4 and connect the other sub. If you connect both subs in parallel, the impedance will be too low causing the amp to overheat and possible fail.
As for the settings: Low pass filter on, crossover somewhere between 80-100, input levels to match your receiver, and bass boost to your personal preference.
Hope this helps.
Aug 13, 2009 | AudioBahn Car Audio & Video
Wiring subs can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
Audiobahn Alum 12
did you try on screwing one?
maybe u cause a vacuum effect if you seal that box so well its a good thing .but check to see if they work oput of box 1st.if they are damage the try this spkr repair site.
Dec 12, 2007 | AudioBahn ALUM12 Car Subwoofer
Kenwood 12" 4-Ohm Single-Voice-Coil Subwoofer Logo
446 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
