I dont know where these thing are but I am electricaly saavy and a service engineer. What readings should I be getting from each part. The machine is running and heating but beeping during most cycles
Hi!
I'm adding a link to a manual of Hoover Tumble. Hope it will help! https://manualsbrain.com/en/manuals/754807/?page=12
Testimonial: "thanks but not what I'm lookin for"
SOURCE: 1998 honda accord check engine light on code p0141
SECONDARY HEATED O2 SENSOR HEATER CIRCUIT FAULT SENSOR 2.
SOURCE: Hotpoint WT960 Fault F-07 heater relay
A few reasons for this, faulty heater, broken wire, faulty pressure switch or faulty main control board (the heater relay is on the main control board).
There is no reset for this.
Unplug the appliance and take the rear cover off.
Check the wiring to the heater and thermostat. Give the wires a good tug as they can break internally and look ok.
If you have a multimeter, test the heater, it should read around 25 ohms.
Take the top off the appliance, locate the pressure switch (has a thin tube on it), give it a few good taps with your screwdriver handle.
Finally, take the main control board out (bottom left when viewed from the rear) and one plug at a time, take them off, clean and tighten them, plug them back on.
If everything checks out ok, then it's likely the main control board is at fault.
Good Luck!!
Thanks
SOURCE: Re-Hoover nextra8 hnc380 Tumble dryer
Had this problem with mine. Its the belt tensioner pulleys that have seized and cause the noise.I got 2 net tensioners and fitted them myself.The parts come to about £15 but its a total strip down to replace the parts. been working fine now for about a year
SOURCE: Hotpoint WD420 Dryer heater relay
You must check for overload try to messure the amount of clothing you adding to the machine, and try to restart by unploging the aparat from the wall outlet, wireing diagram are located usualy on the back of the aparat.
