SOURCE: Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
SOURCE: HOW DO I CHANGE TONER WASTE BOX AND WHERE IS IT ON lexmarkc534
I presume from your question you have a message that has popped up 'Replace the Waste Toner bottle'. This is a consumable item and will need to be replaced every 30000 pages. Emptying the old one is not recomeded as the toner is very fine, very messy, very hard to get spills out of clothing and so you will need to purchase a replacement (instalation instructions provided)
SOURCE: What is a waste toner box. what does it do and. BEWARE THIS NUMBER 1-800-975-0148 IS SPAM HERE
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Testimonial: "I had no clue what a waste toner box is. Your response helped me. Thank you."
SOURCE: I get error message "waste
Open the right side door. there at the bottom is a long plastic bottle full of waste toner. If you have no spare bottle then carefully (dont create dust) empty toner into a bin liner. Now tap the bottle on the table to allow any toner on the sides to fall back to the bottom. now refit and all should be well.
