SOURCE: wiring 4 wird dryer plug to 3 wire 10/3 for 220 welder
the four wire plug seperates the neutral and ground. the three wire just piggybacks the ground to the neutral. so just get a three wire cord that fits the 220 plug on the generator and install it on your dryer make sure to attach the ground correctly for your three wire setup
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
SOURCE: cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
SOURCE: 98 chevrolet silverado k2500 4x4 left rear brake light not workin
I have the full wiring harness for the exterior lights if you need it. Send me a email with a link to this posting and I will send you the diagram. [email protected]
