SOURCE: I need to program my
I am asumeing that the remote is from your dvd recorder/player which you wish to use to control your tv?
Which is possible. please follow the link to Samsung support, there are step by step instructions on how to use your dvd remote to control your tv.
http://skp.samsungcsportal.com/integrated/popup/FaqDetailPopup.jsp?seq=366390&cdsite=uk
SOURCE: How do I connect my ps3 to the Samsung smart tv
For best performance I recommend you connect a HDMI cable from the PS3 to the HDMI input on your TV.
To display the PS3 you need to select the HDMI input on your TV.
SOURCE: How to connect a samsung soundbar to my tv and sat and dvd
Feed the audio from the audio out on your tv to the receiver. Plug your sound bar into the speaker output of the receiver and you should be up and running. You will have to turn on the receiver and control the audio there. The TV may have a setting for external speakers that you need to turn on in the audio menu. Now this is the straight forward approach but there are many factors to consider. One example would be the amplifier output being compatible with your speaker so you don't blow the speaker or the amp or amp/receiver combo.
SOURCE: need instructions how to program Samsung AH59-02131F remote control for Sharp TV
user manual can be found here http://downloadcenter.samsung.com/content/UM/201104/20110420092354545/HT-z320_XAA_3-24[1].pdf
If your soundbar has the input for a toslink, which is an optical sound input you may need to go this route. You will know it by seeing a very small flap with a red light emitting from behind it. Most newer tvs only have this output for sound anymore. Check Amazon for a toslink cable.
