Worth , is personal thing, but boils down to.
what is the cost in shop to fix it, (not cheap)
against a new TV or used,
only you can can answer any question of economics.
you posted TV to computers, and TVs are not. that.
this TV is 13 years old today,
does the TV part work, at all , even on antenna?
That TV has lots of features, do any work at all?
the home screen is dead, (booting is the clue)
so sounds like to me power supply issue inside, making the brain inside dead or its memory banks.
my guess is used, dead, 13 year old TV is only worth $100
for parts.
and tad more working,
I'd upgrade,
SOURCE: Out of Range message on monitor after T5300 finished booting. No Image.
The out of range refers to the screen resolution size of your pc as apposed to the monitor. It is unable to operate at the set refresh rate and screen res.
SOURCE: Toshiba PSA60L-004003
1. Try removing the memory
2. Try removing the hdd (try to use another ide drive)
3. try removing the cdrom
In that order try to remove them clean them, or use a spare, and see if the error pops up again.
SOURCE: Red light flashing. TV wont start.
Bypass the SEINE module if you know how. If you use off air HD you will have to get a new module.
SOURCE: Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
SOURCE: I have a Toshiba 1805-S203 Laptop. When switched
Sounds like the hard drive might have gone bad. Or a virus has corrupted the partition table. Try re-installing Windows.
Notice (Read Prior to Beginning the Software Upgrade)
The following events may interrupt the upgrade process and result in an inoperative unit.
1) DO NOT unplug the Power Cord during the software update procedure
2) Avoid loss or interruption of power during the software update procedure
3) DO NOT Press the power button on the unit during the software update procedure
In the event of software upgrade failure please contact TOSHIBA Customer Service at 1-800-631-3811
