Question about Electrolux Kitchen Ranges
How do you replace indicator light on the warming draw knob of an Electrolux gas range?
3 Suggested Answers
SOURCE:
milten1
  • 1304 Answers
SOURCE: Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Posted on Oct 09, 2009
  • 126 Answers
SOURCE: ge gas range about 7 years old delay in lighting
take burner cap off and clean all the gas ports with paper clip etc.it sounds like the gas is not reaching the spark.usually clogged with grease or soap.hope this helps .please rate my answer :)
Posted on Dec 08, 2009
Blue lights flashing can not get to reset
Hey Troy, I understand that you are having problems with your Electrolux Dual-fuel Range. Have you recently installed the range or had a power outage? When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 26, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
After a power outage. All the lights on the range are blinking/flashing, how do I turn them off? Everything still works. Just can't turn off lights.
Hey Scott, I understand that you are having problems with your Electrolux Dual-fuel Range. When the range is first plugged in, or when the power supply to the range has been interrupted, the indicator lights will flash and the control will beep. To stop the lights from flashing, turn the selector control knob to BAKE and back to OFF. You can also attempt a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
Oct 18, 2015 | Electrolux Icon E30df74gps 30" Pro-style...
I have an Electrolux gas oven free standing that will not light. The red indicator does not glow when the temperature dial is turned on. It has an oven timer, Is the problem the igniter or is there a fuse...
Hello Ray, thanks for your inquiry!
I see that you are having trouble with your Electrolux gas range not lighting properly for oven functions. This could be an issue with your igniter, burner, or control panel. I would suggest performing a reset on your range and you can do that by disconnecting the power from it for roughly ten minutes. You might want to get assistance from a professional technician for proper diagnosis and repairs will require disassembly of your range. A technician will have the appropriate tools needed to diagnosis the range and pinpoint the issue. This will also help prevent any future issues or unnecessary part purchases. -Matt
Mar 08, 2015 | Electrolux Kitchen Ranges
Just started renting house that has the Maytag Performa Electric Range and I noticed last night that the "on indicator" light is on (and still on tis morning); however, none of the burners nor the sto
The pilot indicator is powered by a contact in the thermostat or control board. It is usually not powering the oven but it could be allowing 120 volts to the element this would make the oven very warm. If you unplug the stove for a while and then plug it back in and the oven gets warm again I would have it checked. It may be drawing power.
Sep 24, 2014 | Kitchen Ranges
Hi When I try to light the gas oven, it will light but as soon as I release the button the flame goes out
Are you giving the thermocouple time to warm up?
You have to hold the oven knob in for a while to warm the thermocouple before the oven will stay alight. If you are doing this then the thermocouple needs replacing.
See my other posts for a link and price as it was at that time.
Dec 11, 2009 | New World 50GSO Gas Kitchen Range
Arg7600 oven won't light. Glow plug works. No gas.
This typically indicates the Hot surface ignitor (glow plug) is weak, and needs to be replaced. Even though it glows, it simply doesn't generate the amperage required to open the gas valve. These two compnents work in series, when the igintor becomes to corroded it cannot draw enough current to sufficiently power the magnetic coil in the gas valve. replace the ignitor and let me know when the turkey is ready ! :)
Sep 25, 2009 | Amana ARGS7650SS Gas Kitchen Range
Turn on the burner no flame oven have light but
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
thumbs up
Aug 17, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Will the flame go out if you turn the control knob to the off position?
Sometimes gas cooking control knobs have two seperate types of control in the one knob. One control turn the gas on or off, one adjusts the variable quantity of gas allowed through a gap to your flame jets. Some control knobs can get gummed up and stick a little. The can be fixed by carefully taking apart the control knob, taking note of EXACTLY how everything goes back together and cleaning any gummed up bits. Then reassemble the knob and drizzle soapy water over the control to test for leaks. A leaky gas join blows bubbles and makes noise. Let me know if this fixes the problem.
John
May 08, 2009 | Rangemaster 110 (Gas) Kitchen Range
Kitchen Ranges Logo
54 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
