Magnavox tube TV - No Picture
While watching, the picture went black -- can still see/read captions from shows and the TV's channel display still shows, but there is no picture for any of the channels nor from inputs like the DVD player and VHS.
Seems obvious that the picture tube is the problem -- is this something to repair myself (I can do basic electronic repairs)?
Any suggested parts stores?
Thank you for any help and your time!
  • Mackwd Dec 20, 2007
    I have a blown picture tube. I want to buy and install it myself. It is a emerson Emerson EWF2702 27" TV
    Top Expert:
  • Televison & ... Master
  • 12,962 Answers
If you see any image at all on the screen then it is not the tube. Could be an issue with the tuner or video output of set.
Posted on Jun 20, 2017
  • 236 Answers
SOURCE: TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Posted on Mar 03, 2007
  • 236 Answers
SOURCE: Have sound and OSD but no picture
You may have a problem with the video switching IC. Stargazer
Posted on Aug 29, 2007
  • 1694 Answers
SOURCE: Can't get second picture in Picture-in-Picture (PiP)
Watching two separate tv channels at the same time requires two tv channel sources,i.e. a split of some kind. For instance,the cable coming in thru the wall is split-half to tv or vcr/dvd combo and then to tv,the other half to cable box,then out to tv.If what I described fails,then you may have an actual tv failure.PIP video is generally a separate circuit from standard video.An expert tech w/service literature should be able to help. Let me know if you need more assistance.
Posted on Oct 03, 2007
  • 934 Answers
SOURCE: AV channel on magnavox tv
You should have an "input" or "Source" button that woill allow you to cycle through the inputs available on that unit. Set the DVD up and play it / plugged into one the available in sources. Then cycle through the inputs till you locate it...
Some smaller TV's you can use the TV/VCR button to cycle through and still others will allow changing the channel below channel 2 to get there...
Posted on Nov 05, 2007
  • 3 Answers
SOURCE: magnavox mwd7006 dvd player hookup
How can I hook my Magnavox MWD7006 player up to a entertainment system. So far sound is playing in Stereo (3 speaker) format instead of (six speaker) format or Db5.1. Any ideas? I used a s-video cable to connect.
Posted on Jan 17, 2008
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
Curing the "black box" on some TV channels
Here's the symptom: A mysterious black box covers some or most of the picture on your TV, but not all the time. It may not show up on all channels, or sometimes it disappears only to come back later.
No, it's not the picture tube, it's your closed-captioning. Somehow your TV has been set to "text mode", and the screen is being cleared for text that isn't there. On channels or shows where captions aren't being broadcast, there's no box. But the box returns when captioning is being sent.
Many TV set remote controls have a single button to set closed-caption modes, so it's easy to set a TV to "text" without knowing it. (Especially when you have kids who love to press buttons!) Then when the box pops up, it's a mystery.
Simply press the captioning button on the remote, or use the set's menu, to cycle through the settings until you turn captions off. No more box!
on Jan 31, 2010 | Televison & Video
My TV seem to be on wide screen and it shows half the picture, how do I set it up on full screen? No other material is connected to the TV
If your TV displays a black box type shade on the screen means that your TV may be set to "Text" mode. To clear the screen, select "Caption Off mode".
To do this, press "MENU" button to display menu functions on the screen. Press "channel up or channel down" button to select the function "CAPTION". Press "Volume Up or Volume Down " button to select the mode you wish. There are five modes that you can select; Caption-Off; Caption-C1; Caption-C2; Caption-T1 and Caption-T2. As no other matereial is connected to your TV, you just select "CAPTION-OFF". When done press the Menu button again to exit menu display. Ok.
Oct 22, 2010 | Durabrand DWT1304 13" TV
Was watching TV and the picture just went black (still had sound)
eithor the flyback just craped out or the tube went
try turning up the flyback failing that call a service tech and ask for a quote
quote cose 30-50 bucks
atleast you will know forsurre if it's worth fixing
Aug 06, 2009 | Samsung SPN4235 42 in. Plasma HDTV
hi the problem is the picture tube of ur television has got damaged.. its better to replace a new picture tube...
Jan 24, 2009 | Philips Magnavox 27MS343S 27" TV
Black screen but have sound
If it is not a hardware problem, it is most likely the Closed Captioning system.
If you can still see the on-screen menu, go into your TV's menus and disable Closed Captioning.
May 14, 2008 | Toshiba 36AX60 36" TV
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
Black square in the middle of the picture
You have the set configured to display "text 1 or Text 2" in the closed captioning menu. You will need to turn closed captioning off to get rid of this box.
Jan 13, 2007 | Craig CTV-41904 19" TV
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
