Hi, you need to install USB video capture device before using the software, please check the following link to find driver according to your operating system:
Corel KBSearch Articles
Also the following article can provide you more information:
Installing Easy Vhs To Dvd On Vista Home Premium 32 Sp1
SOURCE: Roxio Easy VHS to DVD install causes PC to hang up.
Do you have any other conflicting software or any other Roxio software? Any other Roxio or Sonic software will cause errors with Easy VHS to DVD.
It's also recommended to download the Service Pack from the Roxio.com site.
SOURCE: I am running Vista and trying to istall easy vhs
If you are using more than one USB devices at a time - especially on the same USB physical port (through a hub, say), then there may be insufficient power for the device. If you unplug the device and plug it back in again (preferably on a physical port to itself), if the device is working ok, windows should pick it up and search/ask you for appropriate drivers or manufacturers disk.
Btw give the device at least 10 seconds after unplugging it before plugging it back in again.
Allan
SOURCE: computer does not recognize the usb
I am not sure what your program has to do with your USB drive. what system are you running?. You may need to uninstall the USB port in device manager and restart your pc and let windows detect it.
SOURCE: video choppy when capturing. Using video to
I will need more info on your PC setup to be able to help you.
