SOURCE: lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
SOURCE: CD Burner
Its caused by a small fault in chip which directs the laser so please complete a service for your Cd-Rw from nearest company authorised service center it may cost you around (916) 636-5785 (8am - 5pm PST) is the customer support number of NEC please call them and find nearest service agent for you iam sure about this solution's application
SOURCE: Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
