Http://etools.cp.com/cpvscatalogue/files/2050560783.pdf I believe you may find your answer there
SOURCE: torque settings for power major
I recomend you buy a workshop manual.
Try here. http://stores.ebay.co.uk/Manual-Finder_Ford-Farm-Industrial_W0QQcolZ4QQdirZ1QQfsubZ14QQftidZ2QQtZkm
Good Luck !
SOURCE: torque setting for 1/4'' - 1'' npt threads
I contacted Aberdeen Fluid Solutions Ltd. They were able to resolve my problem very quickly.
Best Regards;
Jake
SOURCE: Change torque setting on Uryu pneumatic driver
Check out the link below. It will take you to www.FlexibleAssembly.com. They are an URYU distributor and have a lot of technical information listed on their site. This link has specific information on how to adjust the torque on an URYU screwdriver.
http://www.flexibleassembly.com/URYU-LT-Torque-Adjustment
The use of a digital torque tester can be very important when it comes to trying to accurately calibrate your tools. Below is a link to an FAQ page about torque testers. I’ve had a lot of success with using this site to find technical support related information.
http://www.flexibleassembly.com/Torque-Testers-and-Torque-Meters
-Deezy
SOURCE: good day, i need to
Hi rita d ,
the answer to your question according to information supplied by auto data ( the bible to us techs) is 60Nm, then a further 90 degrees. You should also use new bolts. Hope this helps,
Doc Scott
SOURCE: Good day I'm looking for the torque settings for a polo trendline 1.6.. 2011 model please
Which bolts are you tightening? The job the bolt does will affect how tight it has to be. Cylinder head bolts are always considerably tighter compared to the bolt for the sump plug.
