Electronics - Others Logo
Deborah Raleigh Posted on Oct 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Ally Doll is saying she needs her pack? Where is her pack?
I replaced her 3 AAA and 3 AA
Mythnok the Wolf Bat
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 26, 2019
Contributor
Level 1:
Answers
Questions
0
Helped
1361
Points
6
The pack is the box/card/cartridge at her back, under where her batteries should go
hope that helped :)
Ancient god of gaming
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 439 Answers
  • Posted on Oct 08, 2018
Master
Level 3:
Dedicated:
Answers
439
Questions
Helped
191055
Points
2012
When Ally starts chanting "I need my pack", it can become your worst nightmare. I can't find "the pack" but I'm guessing it's the keypad that you plug into her wrist. My bet is the pin/plug connectors in these dolls were not super awesome quality wise and sometimes didn't register they were connected (the program cards were a bit glitchy as well). Once the batteries need replacing, the doll needs to be reprogrammed hence the keypad connection request. Just a guess...
2 Related Answers
Anonymous
  • Posted on Jun 11, 2010
SOURCE: Can you take the Swivel Sweeper battery pack apart
Yes you can if you have a way to cut through the plastic outer case,(I used a Dremel rotary tool). Inside you will find six double A Ni-mh batteries. I found eight of these for sale on ebay for around ten bucks,then all you do is solder some wire to the batteries like the original battery pack and tape up the case and charge.
Anonymous
  • Posted on Apr 17, 2011
SOURCE: How do I program Amazing Ally Doll?
We have tried the reset button and also squeezed both of her palms. What else should we try? Any suggestions?
2answers
It asks for 3 AA batteries and I can't even fit 2 AA in it
its so not true instead try the fatter batteries maybe just one would do it
2answers
6helpful
I lost the instructions for buzz lightyear, how do I cange his batteries?
batteries are located on the back of the legs under knees 4 AA each side and 3 AAA batts on top of the switch on the jet pack i hope this will help you and that you let everyone here know this solved your problem.
1helpful
2answers
I just got a ViviCam T027, what kind of batteries do i need??
for some reason they take either AA OR AAA batteries. remove the batteries and it will say on the side what type. AAA batteries or small. AA are the larger "penlight" batteries. i would suggest/recommend that you purchase a set of rechargable batteries for the camera. 600ma minimum but higher ma would be best. most dept stores such as walmart etc will have charger + battery combination packs you can buy. as a side note buying dollar store batterys etc will be a waste of money as i've tried it. you might get one or two pictures from a set of batteries. your other choice is a good set of alkaline batteries. but rechargable batteries are your best option.
robert
3helpful
Doll is new has not worked right since it was boughten. Before changing batteries mouth and eyes worked. and after changing batteries only mouth moves. what could be wrong ?
Amazing allysen takes two sets of batteries. When you open up her back you will see where you replace 4 AA batteries. If you open up the littel doors UNDER the AA's there is a space for 3 AAA's. That might be a solution.
2answers
I have an Amazing Ally doll that told me her batteries were low so I changed them & now all she says is "I need my pack." What's her pack?
are you surebshe wasn't saying her back you know like what keeps the batteries in she probably has a sensor there
Sep 19, 2010 • Dolly Toys
5helpful
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 • Vacuums
Ally keeps asking for her pack n i think its missing, what can i do?
my device serial number is 351886014554866
plz give me my license number
Top Electronics - Others Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you an Electronics - Other Expert? Answer questions, earn points and help others
