Question about Microwave Ovens
Problems with the fan EMERSON MW8107WA
I have problem with the micro wave when closed the door the fan starting, where i can get a diagram. because i check all the switch and connections and all seem good. I hope your answer THANKS I've got an Emerson MWG9111SL microwave that does not shut off. The fan just keeps running until it's unplugged. When I plug it back in the fan immediately comes on.
  • Anonymous Jan 05, 2008
    Cooling fan will not shut off unless door is opened.
  • Microwave Ovens Master
  • 9,098 Answers
I still suspect a bad door switch or door switch mount, but it may be a stuck relay or bad conneciton on thew control board.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 26, 2007
  • Shell Stuart
    Shell Stuart Aug 09, 2014
    William the link you provided says "HTTP - 404 Page Not Found"
My emerson micro wave started continually running when I open the door.
Could be s defect in the door interlock or a faulty control board.
Mar 17, 2018 | Emerson Microwave Ovens
Emerson Microwave MW9325SL hums when door is closed
You probably have a bad door switch, and maybe a secondary problem. I recommend it be checked.
Apr 09, 2012 | Microwave Ovens
On my emerson microwave model mw81195b, with the door closed on the unit cycled out a fan is still running. The only way to cycle the unit off is to open the door. The microwave functions fine except for...
I am sorry I am unable to answer your question as I too am not having any knowledge of microwaves. My name would hve cropped up because I sought advice from FIXYA regarding some problem on my microwave. Sorry about inability to help.
Sep 08, 2017 | Emerson Microwave Ovens
When door is closed resistance 400 ohms when door opens shorted
If that is across a switch with nothing else connected, I would say it was faulty and change it.
Feb 23, 2011 | Emerson MW8107WA Microwave Oven
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
Door Window steams up on Microwave
Is the internal cooling fan running? You should feel air flow from the grille in the front or back (as the case may be).
If it's just steaming up the inner face of the door, that's fairly normal, but if the steam is appearing inside the layers of the door, that is not normal.
Since it's new and you've got a warranty, I would call Emerson.
Nov 02, 2007 | Emerson MW8107WA Microwave Oven
Fuse problems.
Microwave fuses are usually located inside on the floor of the chassis behind the control panel or on the door switch mount between the switches. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you do need a new fuse, it will be a 15- or 20-amp ceramic fuse, and they are available at local home centers, home improvement stores, hardware stores, and appliance parts stores.
May 16, 2007 | Emerson MW8107WA Microwave Oven
I NEED A ELECTRIC DIAGRAM
Sure man NO Problem. There are two interlock switches in most micro's. Ones for the fan and ones for the magnatron and the transformer. The one for the fan can also control a lite. These micro switchs have a "n"ormally "o"pen position and when they are switched the normally open side closes there for turning on the cuircuit board that then switches on the fan,transformer ect. ect. Two test these switches simply look at the switch and you will see a "c." by one of the connections, That stands for common. Put one end of the ohm meter there. Next you will see "n.o." that stands for normally open so put the other end of the meter there and you should not get any reading. Next push the lever down and then the meter will give you a dirct short reading and should have no resistance at all and if it does measure even a few ohms that switch should be repalce as Ive seen these faulty switchs break down when current is on them and causes all kinds of intemittant connectins. Now with the other connction on the switch if there is one will have a "n.c." by it and that stands for normally closed. With the meter still on the 'c' connection put the meter on the nc without pushing on the switch. It should read a direct short also with no resistance. Now while holding on both same connections push down on the switch and it should not show anything as its wide open with no measurement at all. If it dosent do this then the switch is bad. Now almost every microwave made, there is a wiring diagram inside the outer cover. If its not there you can order one from the company but most micro's are almost all wired the same. Hope this helps. Good Luck
May 12, 2006 | Emerson MW8107WA Microwave Oven
I know you say you checked all the switches and connections, but it sounds like a defect in the control mechanism. A defective microswitch, failure of one of the safety switches etc. Don't try to fix it yourself though as there are safety issues involved (high voltage and radiation) - get a repairman! Considering the low cost of new microwaves plus radiation concerns, you might also want to think about getting a new one.
Apr 04, 2006 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
166 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
