Question about Zenith Televison & Video
I have a Zenith Concierge and we used to be able to wiggle the cord to hear sound but now we have no sound. This would be the cords the have the red, yellow, and white tips.
SOURCE:
SOURCE: No color on dvd player
A cable could cause this problem. I would try using a standard RCA patch cable and go from the composite video output of the DVD player to a composite video input of the TV. See if that produces color. If not, the DVD may be at fault. On the other hand, if you get normal color, the S-video cable could be bad.
Hope this helps.
Posted on Dec 21, 2008
SOURCE: After connecting Insignia converter box to TV, there is no sound.
I think you're going to need a RF modulator. 15 to 20 bucks on Amazon\Radio shack
Posted on Jan 16, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Zenith TV has no place for yellow, red, white composite plugs
This TV doesn't have an AV input, so there are no input jacks other than the antenna connector. If you want to connect a device that has only AV outputs (your red, white and yellow plug) you will need an RF converter. This will take the AV signals and convert them to a channel 3 or 4 signal you can tune in on the set.
But since you don't seem interested in spending any money, you'll probably not like to hear that the converter runs around $15 most places. Take heart, there is an alternative. Find a VCR (if you don't have one already) that has an RF output. Many of the the newer DVD/VCR combos only have AV outputs. You're looking for one that has an "out to TV" threaded connector on the back. These units already have an RF converter built in. Connect your AV plugs to the line in jacks on the VCR and switch to that input, and you can use your video game or DVD player through the VCR.
Posted on Jun 20, 2009
  • 10 Answers
SOURCE: whats the name of that cord with the yellow red
It is called the composite cable. Here is a link on Amazon.com for one at $2.01. LINK
Posted on Jul 08, 2009
caroldon
  • 17130 Answers
SOURCE: When I hook my dvd player up using the red white
The yellow must go to the video and the sound L&R to the audio inputs. If there is no video after selection of the AV, then it is possible that the input video amplifier is faulty. If there is a second AV2 port then use it or else you might need a modulator to connecct vis the RF input.
Other wise the set must be opened to check for failure off the video amp, protection diode at the input.
Posted on Sep 21, 2010
Hello, I have a Zenith Concierge model number
http://www.manualsdir.com/manuals/228916/zenith-concierge-h25f39dt-concierge-h24f39dt-concierge-h27f39dt.html
Jul 02, 2017 | Televison & Video
My ps3 turns on but is not showing anything on my tv screen
If you are using the red white yellow cords then wiggle the yesllo cord thats the picture cord were it comes though and if that dont work make sure all the cords and in tite
May 29, 2010 | Sony Playstation 3 (PS3) Console
Need help with my suround sound system
try wiggling the cords.i think it's open from the inside of the cord.sometimes attaching and pulling cords is the cause of no sound at all.check your cords for open.you can use a battery and a small lamp and wires.make a circuit of a lamp.then, get one wire from the small flashbulb and use it as a probe.the wire from the battery is the other.hook it up to your cords touching the one end ,like completing the circuit.if the bulb lights up it means it's ok and if not, your cord is open.
May 15, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Need a power cord for a Zenith L20V26C 20.1 in. LCD Television
You can find a replacement power cord for this model from a major Zenith/LG parts distributor at the following link:
Zenith/LG L20V26C Replacement Part Power Cord
Please note the AC Adapter is no longer available from the manufacturer as you can see here.
Jan 29, 2009 | Zenith L20V26C 20.1 in. LCD Television
We have a zenith concierge tv that was donated to a group home. WE have tried programming it so that the cable tv stations can be used but it has a lock on the auto program and I can't figure out how to...
You have to purchase the master remote from Zenith or a hotel supply company. This is the only way to gain access to programming the concierge. The remote is currently $24.99.
Jan 22, 2009 | Televison & Video
Panasonic KX-T7736 cuts out until cord is moved around
change cords to see if that works. Trouble shoot from there if it doesn't.
Apr 02, 2017 | Panasonic KX-T7736 Corded Phone (KXT7736)
No sound
The S-Video cord is for the picture only. You must connect the audio out behind the dvd player (the red and white jack) using a double male-to-male RCA cable to the" Audio In" in the TV to get sound.
Mar 18, 2008 | Panasonic DVD-RV31 DVD Player
Televison & Video Logo
42 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
