Question about Lorus Watches
How to change the date on a Lorus Youth Watch using the nob at the side of the watch
  • Lorus Master
  • 7,447 Answers
If you can identify the model from the picture, click on it to download an instruction manual.
http://www.loruswatches.com/Products/Kids
If not successful, please contact the manufacturer to request a copy of an instruction manual.
SEIKO U.K. Limited
SC House
Vanwall Road, Maidenhead
Berkshire, SL6 4UW UK
Tel: +44 (0) 1628 770988
Email: service@seiko.co.uk
Posted on Oct 06, 2018
  • 203 Answers
SOURCE: Change the date on my TAG Watch
if it has hands the winder will be screwed in undo this anti clockwise then click it out once for date twice for time, if this helps please rate me joe
Posted on Nov 22, 2008
SOURCE: Can't adjust the date on a digital watch
These are the instructions for the AD0721. They might apply to your model, too. I hope this helps:
http://img261.imageshack.us/img261/6784/manualr.jpg
The analog setting of the watch takes place by pulling out the knob (kind of tough) and adjusting, like a regular analog watch. The analog and digital displays are will NOT stay in sync, unfortunately.
Good luck.
PC
Posted on Jun 05, 2009
mcdevito75
  • 1970 Answers
SOURCE: unscrew the back of a lorus watch
mcdevito75 here, Most Lorus watches use a press fit back cover on their watches, simply us e a knife with a sharp edge between the case and cover and with a slight twisting motion the cover should come off, Also Look for any slots in the cover that match a slot in the case, or a very slight extension or lip on the cover, this is where you"d place the knife and use a slight twisting motion to remove the cover. If there are screws on the back cover you"ll need to remove those screws to get the cover off. Your Local small watch repair shop can help out.
Posted on Jun 21, 2010
  • 2501 Answers
SOURCE: I have lost the instruction
Go to http://www.loruswatches.com/instructions.asp and fill in the details of your watch, to obtain your instructions.
Posted on Jan 10, 2011
  • 2501 Answers
SOURCE: Hi, My watch is changing date at 12 noon instead
Your watch is 12 hours out of step. (The date changes every second revolution of the hour hand.)
Wind your watch forward 12 hours, (you may have to reset the date) and it will then change around midnight.
Posted on Jun 08, 2011
I need to change the time on my lorus digital watch
Try Googling (lorus)(model)(manual) without parens for instructions.
Apr 01, 2018 | Lorus Watches
How to set time on a Lorus watch Z001 X001
Digital
Press the button on the bottom left-hand side of the watch to change between the modes on the watch.
Press and hold the button on the bottom left-hand side of the watch for two seconds until the seconds begin to flash.
Press the button on the top right-hand side of the watch to set the seconds to "00" and press again to set.
Press the button on the top right-hand side of the watch again until the hours flash. Press the button on the bottom right-hand side of the watch to change the hour display. Press the button on the top right-hand side of the watch to set.
Repeat step 4 to set the year, month and day on the watch.
Analog
Pull the small knob on the right-hand side of the watch, also known as the crown, out one click.
Turn the crown until the previous day's date is displayed.
Pull the crown out one more click. Turn until five minutes ahead of the correct time and then turn back to the correct time.
Push the crown back to the side of the watch. The watch is now set.
Mar 31, 2018 | Lorus Watches
Set time and date on lorus digital watch
I NEED A BATTRY Y131A OR A REPLACEMENT FOR MY WATCH.
Mar 24, 2012 | Lorus Watches
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 | Watches
My gold Mickey mouse Lorus watch was opened a part damaged by the person replacing the battery. This is not a digital watch, but has nthe mouse with hands and a second wheel at bottom.
You are probably going to have to look for an identical watch for parts.You might try this site:
http://www.esslinger.com/watchparts.aspx?gclid=COCr3t2F9KUCFcIKKgodgiARnA which is parts for watches. I'd have a look on ebay as well for a watch that is not working. Of course it does depend on the part you are looking for. I am also wondering if the inner parts for another Lorus mickey moue watch might fit, but maybe you don;t wish to change it out from the original.
Dec 17, 2010 | Disney Lorus Out of Production Collectible...
How to set the alarm on the lorus rf33bx9
If you put "lorus watches" into your search engine you should come up with the Lorus web site.
One of the options given is "instructions", click on this and you will be asked to enter details off the back of your watch.
Feb 11, 2010 | Bulova Watch
I have a Lorus NX11A multifunction watch and have no manual. I have been on the Lorus website but it might as well be written in Japanese
mcdevito75 here, I would imagine this is a Mickey Mouse Lorus watch by the picture supplied. If it Has DAY / DATE function, here"s what to do, --- To set the DAY, pull the stem out to set, keep turning the hads till you rech the day, then push in the stem. To Change the DATE 9 number) slip your fingernail just under the stem and lift it to it"s first position (notch) this should allow you to change the DATE (number) without haveing to turn the hands so many times.
Jun 24, 2009 | Disney Lorus Out of Production Collectible...
Watches Logo
137 people viewed this question
Top Lorus Watches Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
gautam jha
Level 1 Expert
Are you a Lorus Watch Expert? Answer questions, earn points and help others
