I have a Traeger, not a Pit Boss, but assuming they work on the same theory, you generally want to smoke at 225-250. The "smoke" setting is usually much lower than that (for smoking cheeses and such). Once you set your temp, your auger will feed pellets into your fire box on a timed cycle determined by your heat setting or thermostat. So you'll actually only see smoke every once in awhile.
Google for your owner's manual by model number. But I don't think the Pit Boss has a fuse. Are you plugging it into a circuit with a Ground Fault Interrupter? Maybe you just need to reset the GFI by pushing the little button on the outlet.
If your Pit Boss 820 pellet grill is not maintaining the set temperature and continues to climb, there could be a few potential causes.
Damaged temperature probe: The temperature probe is responsible for sending the temperature readings to the controller. If it's damaged or malfunctioning, the controller may not be able to regulate the temperature properly.
Faulty controller: If the temperature probe is working correctly, the controller could be the problem. If the controller is faulty, it may not be able to read the temperature correctly and regulate the temperature properly.
Airflow obstruction: Another possible cause is an obstruction in the airflow. If the airflow is restricted, it can cause the grill to overheat.
To troubleshoot this issue, start by checking the temperature probe and controller for any visible damage or signs of malfunction. If they appear to be functioning correctly, check for any obstructions in the airflow. If the issue persists, it's recommended to contact the manufacturer or a qualified technician for further assistance.
that battery is to go inside the button unscrew it from the front a spring will come out and you insert the battery inside the hole positive facing out screw it back together and bingo it will light
