How can i tell if microwave is leaking
The only way to tell for sure is to use a microwave leakage tester, which is an electronic instrument calibrated to standards for an accurate measurement. They are fairly expensive, so you aren't likely to run out and buy one. If you have reason to think your oven is leaking, you should call for service or take the oven in to a shop where they should have a tester.
Unless something has happened to damage the door sealing surfaces, your oven should not be leaking microwave. Check that the inside of the door and edges of the cooking cavity are kept clean of built-up food. Look at the door when it's closed. If it's straight side-to-side and is closing properly all around there should be no problem.
Do not believe the claim that you can test for leakage by calling a cell phone placed in the oven, and if the phone rings the oven is leaking microwaves. The shielding in a microwave is not effective at cell phone frequencies, which are much lower than microwaves. The phone will ring normally even in an oven with no measured leakage.
