Question about The Watches
How do I put the back on your watch? - The Watches
    Top Expert:
  • The Master
  • 47,878 Answers
Take it to a jeweler
Posted on Oct 05, 2018
I have a vivani conture watch cant take of the watch off to put the battery in
A process called knifing is used to remove some watch backs but it has to be done carefully to prevent damage to the case or yourself
Oct 26, 2012 | Watches
I have an Relic Fossil Brand Watch and I took the back Cover Off and I cant Get the **** thing back on.. how do you put the back of it back on?...
try to press on as much around as you can then whatever area is still showing a gap gently push it on a corner of a desk ( be careful of crystal), but it sounds like you may not be able to get it back on. Watches need even pressure all the way around to put the backs back on this is done with a watch press. The watch press cups the crystal and applies even pressure to snap the back on. It sounds like you will have to go to your local jeweler. We use the watch press to put on about 75 percent of our backs! Fossil is especially known for difficult backs and crystals that easily break! although they are a nice looking watch!! hope this helps!!
Sep 20, 2011 | Watches
How do I put the bezel of a Time Expedition Indiglo wristwatch back on? I've done everything shy of driving over it with the car.
you need a watch press to put the watch back on
find the correct size disk for both sides of the watches and then press down untill you here the pop of the back .
If you do not have a press you can try to use a small jeweler hammer and hammering it back on . Only a jeweler with plastic head can you use. You also have to have a sponge or something to put the face down and not get ruined when hammering.
You will need to be very careful
lay watch face down on sponge or thick cloth.
align watch back with proper groove where knife fits in to pop back off
Gently start hammering around the edges of the watch back case.
Do so with increasing pressure until watch seals back on .
If you cannot hammer back on without damaging stop and bring it in to a professional
Oct 18, 2010 | Watches
I have a lorus mickey mouse watch just replace battery having trouble with putting the back cover back on..
You may need to have a local jeweler who has a watch press to put it back on, If you put to much pressure on the inside of the back, it may be warped. A knowledgeable jeweler should be able to fix that issue also.
Thank you for contacting FixYa..
Jewel
Aug 31, 2010 | Watches
Putting back on timex watch
There is a press to put this back on.
RECOMENDATION:
Seek professional help.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 11, 2010 | Bulova Watch
How do you put the back, back onto this fs1? The band keeps getting in the way! Back came off easily enough, popped off after unscrewed. Band is still on watch, have tried to slide back into grooves but...
You have to remove band in order to fit caseback back onto the watch. Insert pocket knife blade between band and case lug and pry inwards. This motion should release the band. It will be a lot more difficult to fit the band back on and you will probably need to buy springbar tool. Rate me plz.
Mar 03, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
Second hand is off, how do I get into the watch to put it back?
in order to put hand back to post you need to open watch remove stem system,
then you able to put the hand back on post
you need special tools & experiance I personally suggest take it to watch repair shop close to you
if you are in chicago
you can bring it to us at
AmFix Jewelry & Watch repair
203 N. LaSalle St
chicago, IL 60601
312 641 7000
www.goamfix.com
Aug 27, 2009 | Watches
Watch
I would recommend you to go to a Juwelry, or a watchmaker and let him put the plate back on it. They might do it for free, or it will cost you 3-5 euros/dollars, nothing much;)
Jun 26, 2009 | Watches
Can't put (back) back on my timex indiglo
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
Jan 11, 2009 | Timex 27191 Wristwatch
HELP !! can't snap armitron watch cover back on
Take a small thin piece of cloth or paper towel, fold it and use to cover the watch face.  Put one quarter (coin) on top and one quarter (coin) on the bottom.  Place the sandwich in a pair of pliers, center thhe pliers and press, when you hear the snap, the back is on.  Do not use on a watch with a domed crystal, or at least use a lot more padding over the face.  Takes 10 seconds.
Jan 20, 2008 | Watches
Watches Logo
150 people viewed this question
Top The Watches Experts
D. E. Hev
gbob59
Aaron Thoma
Level 1 Expert
Are you a The Watch Expert? Answer questions, earn points and help others
