Question about Toshiba 52HM95 52" HDTV Projection Television
Sound I have a satellite dish connected to my 52" toshiba. I can't get the stereo sound to come on, I only have a dvd player and a tape player connected. When you get to the stereo choice it is greyed out and you can't select it. Can you help?
  • 979 Answers
You must be recieving a stereo signal for the set to recognize and offer the stereo option. That is more than likely why that option currently is grayed out...accordianman
Posted on Mar 09, 2008
The volume on my Toshiba CT-852 TV will not work with dish satellite but will work with DVD player
It is not the TV----How are you hooked up from the Satellite and what other inputs does the set have other than the coax or cable fitting?
Mar 13, 2012 | Toshiba Televison & Video
Since change over to digital dvd/vcr Toshiba SD-37VB does not record on Video tapes. What do I need to do to correct this or do I need to purchase some additional unit?
Subcribe to cable or satellite tv services.Ur dvd/vcr unit will able to be used to record on VHS tapes again.Because cable or satellite tv services the tv incomming broadcasting tv signal still do broadcasting comming in as analog tv signal for the analog devices as analog devices require as it needed.
Apr 27, 2011 | Toshiba SD37VB DVD Player / VCR Combo
We have a VIP 722 and the second channel is now without sound. We have sound on channel 1 but not 2. Any ideas?
Step 1: Check that TV or Stereo is not muted
Make sure that your TV or Stereo has not beed muted and that the volume is turned up loud enough to hear.
Step 2: Reset Receiver
If the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
Please note: It may take up to 5 minutes for the reset process to be completed.
Step 3: Check Receiver-to-TV Configuration
Check that the wiring between your DISH receiver and your TV is configured properly.
Step 4: Secure Receiver-to-TV Connections
Check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure.
Mar 10, 2011 | DISH Network ViP722 DTV Receiver /...
Set t.v /remote to work with other components
Do you have a Sanyo Universal Remote ? If not, you program your dish 500 remote for these.
Sep 16, 2009 | Sanyo DS31590 31" TV
Hooking up dvd player to Toshiba DPL 52" HDTV
Send the viseo to the Tv using composite or component input and send the audio ( red and white RCA audio ) to the BOSE.
May 13, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Dish satellite i can not record
It sounds like you got a bad reciever or the setting on the meuy of it it wrong!
Nov 19, 2008 | iLO DVDR05 DVD Recorder
Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $ might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Nov 17, 2008 | Bose 901 VI Main / Stereo Speaker
Toshiba 52hm95 DLP HDTV - no sound
What cables are you using? Some TV's and DVD players have options to set your audio source. My DVP5982 I have to set it to HDMI digital audio, check to see if you have that on your TV.
Jul 04, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba VCR/DVD Recorder Combo - Problems connecting it to system
I was able to connect to my cable box. I used RCA (yellow, red, white) cabling. I connected the Video Out on the cable box to the Video In on the DVD/VC (to the DVD VCR cabling section). I then from same section used the Video Out using RCA Cabling to the the Video In connectors on my Phillips LCD TV. That left only to connect the TV to the cable box using regular TV coax cable. Everything works, although I am going nuts trying to dub from VCR to DVD-R or +R discs.
May 21, 2008 | Televison & Video
Toshiba 52HM95 52" HDTV Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
