Question about The Office Equipment & Supplies
Which setting should I have it on for the calculator to perform as a calculator?
    Sergeant:
  • 159 Answers
F321== number of decimal places in the answer, use F
3/4 rounds the answer up or down.
Posted on Oct 05, 2018
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
How do I set up my Casio fx-115ES to perform algebra?
This calculator cannot manipulate letter symbols, so it cannot do algebra. It can only use numbers whose values are known to it: either those on display, or those stored in variables A to E or F , X, Y, and M.
Sep 08, 2013 | Casio FX-115ES Scientific Calculator
I CANT GET MYCALCULATOR TO DO FRACTIONS CAN YOU HOPE ME
To configure the calculator to do fractions, set the Input/Output mode to MathIO.
Press [SHIFT][MODE] to open (SetUp) then select [1:MathIO].
After you set it to MathIO, pressing the fraction key will display a fraction template where you can enter numerator and denominator as you would by hand (horizontal fraction bar). Also, the calculator will display results as fractions and radicals whenever possible.
To perform arithmetic operations on fractions use the regular operation keys (x, +, -, /). The calculator will perform the operations and display the results as fractions (whenever possible).
Aug 15, 2011 | Casio fx-300ES Calculator
How do you turn frequency on when in the stats table mode on a casio fx-9750gii?
There is no such thing as turning the frequency on on the Casio calculators. Just enter your data in lists. Choose one List where you put the frequency information. When you want to GRAPH or perform CALCulations you have a TAB labeled SET corresponding to key F6:SET. When you press F6, a new screen open where you assign the list to the variables.
Here are a few screen captures to help you.
Press F2:CALC (or F1 Graph). The Tab SET appears at the bottom of screen
Press F6:SET
Higlight the line 1-Var Freq (or 2-Var Freq). The bottom of screen shows F1:1 and F2:LIST. If frequencies are not equal to 1, press F2:LIST to assign the frequency list. I entered 2.
List2 is now the frequency list.
Press EXE to perform stats.
See that n=19.
May 19, 2011 | Casio FX9750GII Graphic Calculator
My calculator is set at a 5% tax rate. How do I reset it to a 6% tax rate?
Observe the devices function keys to ascertain any menu or mulltifunction buttons. Multifunction keys perform several features. First the multi key integrates several features to minimise the extraneous requirements wit micro computer keypads. Second, multifucntion keys perform the additional fucntions least visible at initial observation. Calculors as simple computers onlyl produce transaction requests though allowing to adjust features to suit productivity. Perform an observe of the device to familiarise with the adjustment status condition. In the instance were the device were dessign least to allow an alteration of calcultion percentages makes alteration unachievable. Refer to the devices oner user guide to ascertain the capacities if functionalities among several resources made available from the manufacturer.
Feb 13, 2011 | Casio DR-210HD Calculator
How to perform this calculation on a TI-83 plus? 3.632/4.901=inv tan? what to press for inv?
Set your calculator to the DEGree mode. Then 2nd and tan buttons.
See captured image
Sep 22, 2010 | Texas Instruments TI-83 Plus Calculator
How to get mod on it
If you are thinkink of the modulo function, usually shortened to mod(, I am sorry to say it but that function does not exist on the calculator.
However, there is MODE button that one uses to set the operation mode of the calculator.
You have three principal mode setting
COMP: the general computational mode
SD: a statistics mode to calculate Standard Deviations
REG: to perform REGression analyses on statitical data.
Once you have chosen the preferred calculator mode (COMP, SD, or REG) other choices (dependent on the main calculator mode) will be available.
May 03, 2010 | Casio fx-300ES Calculator
Okay... im dumb and i tried to put games on my calculator but that failed... i now have something goofy going on with my graph... the asymptote is different then factory settings... i also have wierd...
[2nd][MEM][7:reset][1:All ram][2:Reset] Memory cleared displays on screen. Some games remain stuck in memory, preventing you calculator from performing correctly.
No you are not dumb. You just have to learn how to get youself out of an unpleasant situation. Truth is a set of corrected errors.
Hope it helps.
Sep 09, 2009 | Texas Instruments TI-84 Plus Silver...
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
Ten zeros when you start
The Fix sign on the top of the screen (smaller size) are indicators that calculator is using the FIXed format: All numbers are displayed with a fixed number of decimal digits (in you case it may have been set to 9 decimal digits). You can change that in the setup.
The Grad symbol means that the angle unit is set to grad. This too can be changed to degrees or radians in the set up.
A sure way to achieve mastery of calculator use is to learn how to configure it to fit the types of calculations to be performed.
Hope it helps.
Nov 24, 2008 | Sharp EL-531VB Calculator
152 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
