Question about KitchenAid Refrigerators
How to trigger KitchenAid Kfis29bbms00 Force defrost mode?
My evaporator freezes up & wondering if there is a test to see if the board is bad or the defrost heater element is bad. freezes up to the point the fan bladed hits on the ice build up.
    Top Expert:
  • KitchenAid Master
  • 4,985 Answers
Heater and bi-metal defrost thermostat can be tested for continuity with an ohm meter. If both of them are good, then board is bad.
Posted on Oct 05, 2018
aborcass
  • 2651 Answers
SOURCE: evaporator not defrosting
element can be checked by continuity test, you should have continuity through it. theres a defrost thermostat clipped to the top of the evap also common to go bad.. closes at specific temp ( written on side of thermo) allowing heater to come on, if it remains open the heater wont be energized
Posted on Mar 07, 2008
zeusfaber
  • 247 Answers
SOURCE: evaporator fan jams with ice buildup from drain
Could be that, or it could be the temperature sensor on the evaporator - if that goes, then as soon as the freezer starts a defrost cycle, it will think it's got the evaporator hot enough and will start cooling again.
Suggest you let the freezer thaw out then, with a voltmeter connected across the terminals on the board which connect to the sensor, turn the freezer on and see if the sensor reacts sensibly to the evaporator cooling down. It's usually done with a thermistor, but just for the moment, I can't remember whether it's usually a PTC or an NTC.
That way, if it is the sensor, you'll be spared the expense of replacing a serviceable pcb.
A.
Posted on Apr 13, 2008
  • 1073 Answers
SOURCE: evaporator fan blade jams in ice buildup
check the defrost bimatal or defrost thermanstat it will be located on the evaperator suction line (large line) it should read continuity with the ref cold if it showes continuity then the defrost timer is the problem
tborn6
  • 700 Answers
SOURCE: Evaporator coil frosted up on Samsung RS267LABP Refrig side
TAKE AND DISCONNECT THE POWER TO TH UNIT AND ON THE VERY BACK THERE IS A CONTROL BOARD THE IS UNDERNEITH A WHITE PLASTIC COVER THAT YOU WILL HAVE TO REMOVE THEN DISCONNECT AND RECONNECT THE WIRES TO THE CONTROL BOARD AND SEE IF THAT DOESTHE TRICK.
Posted on Mar 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
I have a Kitchenaid frig model KFIS29BBMS00 that is not cooling at all. I have replaced both boards and frans are running and coils are clear. It’s not in demo mode. The compressor is running. Help
The compressor may be running, but if there's been a refrigerant leak, it will be running very hot. If it's run like that for more than the very shortest instant, the compressor will be burned out and will need replacement... note that repairing the leak and the system being flushed is vital when the compressor is replaced.
The good news is that it's a warranty repair. The bad news is you need to have a warranty - if it's very old, the callout charge, parts and labor may be more than it's worth in which case put the money towards a replacement.
Sep 25, 2018 | KitchenAid Refrigerators
Ge side by side refrigerator freezes then immediately thaws
replace the evaporator thermistor located on the top of this coil behind the inside freezers rear cover panel,it looks like a small 22 caliber bullet and has 2 small white wires protruding from the one end,this reads the evaporator coil temperature info and determines when to defrost the evaporator coil,a good way to test it is to open the control board in the rear of the unit unplug the upper right J1 connector and measure pin 1 and 5 for resistance of approximately 16,000 ohms when the thermistor is un-clipped off the evaporator and immersed into a glass of ice water for at least 5 minutes prior
Nov 15, 2012 | Refrigerators
How to test defrost timer circuit board
Good day,
With the machine running at least 6 hours, unplug. Wait for a period in excess, of 30 seconds.
Then turn the thermostat off.
Plug in.
This should place it into the defrost mode, turning the main heater in the freezer on, if...........
The defrost thermostat (terminator) mounted on the top of the evaporator coil coil is good. If the terminator is bad, the test will fail.
If your problem is the coil is frosting up, This machine is made by Whirlpool.
The board and terminator, have a fairly high failure rate. In fact, whirlpool has substituted a timer for the board on many of these models.
The price of both, is low enough, that replacing both makes sense.
Dec 03, 2009 | KitchenAid Refrigerators
Build in kitchenaid, freezer working but not freezing
This video I made how to change evaporator on Thermador refrigerator, which is just copy of of Build in Kitchenaid. Problem was that it was running, but ice cream never got frozen. I checked pressures, was low on freon. I checked evaporator coils - found out that defrost heater got deformed and was touching evaporator coils - so it burned holes, where freon started to leak.( I think it designed not best way). Defrost heater on this fridges way to close to evaporator coils. Check this video to get an idea what Im talking about. I hope That helps u to understand why this repair is so expensive and what causing it.
May 08, 2009 | KitchenAid KSCS25FKSS Side by Side...
Lots of moisture in freezer, barely freezing
The problem is that the unit is not initiating the defrost cycle. This can be caused by a bad defrost heater. This can be tested with an ohm meter to see if it has continuity. It can also be caused by a bad temperature sensor, this can also be tested by an ohm meter. (it should change resistance based on temperature) It can also be caused by the defrost timer failing (this is a microcontroller board in newer units)
May 07, 2009 | KitchenAid KTRS22EM Top Freezer...
GE refrigerator gsl25xgwss defrost problem
Either heater or Board is most likely bad. You can remove heater and test it with ohm meter for continuity
Oct 05, 2017 | GE GSL25XGWSS Stainless Steel Side by Side...
Defrost heater not cycling
sound like to me you have a wire terminal short on the neutral side between you def. t-stat and the adc
go to www.servicematters.com for the service bulletin on this issue
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 01, 2008 | KitchenAid Refrigerators
Defrost issues
If it's around 2-3 years old, my first guess would be the heater is bad. The GSS models have problems with the heater almost always about that time.
Test the heater and the defrost thermostat for continuity with a multimeter. Whichever one doesn't get continuity is bad and should be replaced. If they are both good and the evaporator fan is running like it should, it will be the main control board located on the back of the unit.
Click here to see the defrost heater
Click here to see the defrost thermostat
Click here to see the main control board
Let me know if you have any other questions about this issue.
Mar 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MSD2356 Freezer frosts up quickly, fridge warm
If you jumped the defrost board and it went into defrost then that board is bad. I assume by "freezes up" you are talking about the evaporator is frosting up? That defrost board puts it into defrost automatically. If you have to jump it to get it go into defrost then the board is not doing its job.
Nov 16, 2007 | Maytag 23 cu. ft. Side-by-Side...
Refrigerators Logo
423 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
