Question about Sony MDR-7506 Professional Headphones
How to Rewire Sony MDR-7506 headphones
I need to rewire my Sony MDR-7506 headphones. Where can I get the wire other than Sony and how do you get into the headphone.
  • paulkroeger Jan 22, 2008
  • 4 Answers
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Posted on Apr 03, 2009
    New Friend:
Theres a blue chord! apperently this is unknown to everybody on the planet...
Posted on Nov 12, 2013
    New Friend:
I just have the side cable broken and need to basically attach them together again. but there are 2 cables (red and copper). Which one carries the audio signal. This cable is the one on the right side that connects directly to the speaker (the exposed cable between the head band and the speaker. HelP!
Posted on Nov 09, 2013
Download a schematic parts diagram of the MDR-7506 from Sony, and replace it with another lead.
Posted on Sep 29, 2008
Sony wireless headphones keep shutting off
Check up the batteries and replace by new one.
Or remove the battery and reinsert.
Sep 09, 2014 | Sony MDR-7506 Professional Headphones
My earphones i jst bought have been torn on part of the wire and now no sound is comming out of it. Is there any way i can fix it?
If they are new return them to where you bought them or contact the maker. You are entitled to your money back or a replacement. DO NOT attempt to fix them.
Mar 08, 2011 | Sony MDR-7506 Professional Headphones
I am looking for replacement earpads for Sony MDR V600 headphones. Will replacement pads for MDR 7506 fit the V600?
Yes, the replacement pad for mdr 7506 fits in for the v600. They can be replaced for one another. There are different types of v600 and 7506, You just have to look for the 7506 that looks more like the v600. That should do the job for you. Hope this information helped You.
Jan 13, 2011 | Sony MDR-V6 Professional Headphones
How to disassemble sony mdr 7506 headphones to replace the earpads
I find that most headphones have to be opened up by going in through the part that fits to your ear. You might have use force to remove the foam covering, with that gone you should see a few screws.
Oct 07, 2010 | Sony MDR-7506 Professional Headphones
The Right side no longer works!
See my newly posted tip on headphones, if that might help your problem.
Apr 08, 2010 | Sony MDR-7506 Professional Headphones
My sony mdr-7506 headphones stopped working, anyway to fix them, i love them
As long as there is no inbuilt amp or something special to this make, then the problem will be most likely the cable or the Jack plug at the end. There will have a clean break (internal) cutting off all sound. If you are good with a soldering iron then you should be able to get a new cable with plug, or you can try cutting the old jack and fitting a new plug. If you need to go inside to fit the cable then the access screws will be under the foam and ear pads.
Dec 14, 2009 | Sony MDR-7506 Professional Headphones
MDR-7506 - No sound on right side
It sounds like the pin cracked. If this is the case, you'll need to soldier a new jack on it. Here's how, assuming you already know how to soldier a new 1/8" TRS phono plug.
Cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Nov 01, 2008 | Sony MDR-7506 Professional Headphones
Sony 7506 Headphone Replacement Drivers
One of the channels on my MDR-7506 gets a little fuzzy in the bass intermittently, too. It's got a sound like there's just some hair or something in there; it doesn't sound like an electrical noise. This is not a very professional solution, but I found the problem goes away if I give it a good tap with my finger, right on the driver (the part that faces your ear). No need to remove the covers or anything. The delicate parts of the driver are well protected from something as blunt as your finger. As long as you're not pounding on it or jamming things into it, there's no danger of doing more damage. In mine the symptom is a minor inconvenience, so I'm not inclined to buy new ones yet. I heard that special ordering each driver from Sony costs almost as much as a whole new unit, so repair isn't cost-effective if the driver really needs to be replaced.
As for replacement, well, for durable, multi-purpose headphones with great range at a reasonable price, the MDR-7506 can't be beat. Some people say they think the high end is too bright on these, and the low as well, but if you've got normal patterns of hearing loss, you probably need the slight boosts, IMHO. Just don't switch to anything else without testing them out with your own music first; if you go shopping for something different, go to a store that lets you test the phones and bring some CDs and/or a portable player with music you're familiar with.
May 19, 2008 | Sony MDR-7506 Professional Headphones
Worn and torn pads
yes, i've seen them for sale at online shops for $10 per pad. i've never changed any though. the sony's can be disassembled via phillip head screws. good luck.
Mar 06, 2008 | Sony MDR-7506 Professional Headphones
How to replace blown driver.
By the time you buy a driver from Sony for $78 you may as well just buy a whole new set for $94.
Jan 17, 2008 | Sony MDR-7506 Professional Headphones
Sony MDR-7506 Professional Headphones Logo
5,811 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
