Question about Cobra 148 GTL 120-Channels Base CB Radio
Cobra 2000gtl no sound comeing out but will talk on am and ssb can you help
Everyone tells me that they can hear me good on am and ssb very good but i can;t get any sound comeing out of it or no incomeing sight on the meter the meter don;t not move any even if i key a other cb up sitting right next to it could you tell me what to look for or what to change to fix this i really do like my cobra 2000 and would like to see it playing on the air again thanks for any help
Because you have transmit, more than likely your audio section is OK as much of it is shared with the receive side. A final test of the audio section is to check out the PA function. If it works most of the audio section has been tested.
The signals for the meter movement and receiver sound are developed in the audio detector circuit (diodes D21 and D22) just past the I.F. stages (Transistors TR16, TR17, and TR18). I have seen these diodes fail. They are frail little guys, but are inexpensive. I would recommend replacing them first. Pay particuliar attention to which way the band on the diode is positioned and limit your soldering time. If that does'nt rectify the problem, (no pun intended) you can look at the transitors.
By the way, MOVE that second test radio farther away or you could overload the front end of your Cobra creating even more problems. Good Luck, 302
Posted on Nov 29, 2007
I have a Cobra 2000GTL that blew a fuse. After replacing the fuse I realized I wasn't hearing anything. I looked at the frequency it is at 27.825 instead of the 27.185. How can I correct this?
You jumped into the Ham band and you should take it to a tech before you continue using it. You should check the other channels too. Start with 26.965 and go to 27.405. For no reason other than checking maybe do upper and lower SB also.
Mar 01, 2017 | Cobra Radio Communications
Hi, I have a Cobra 2000GTL Taiwan made PC board number pc497ab The set has been stored for a while (couple of years) and I just received it,I switched it on and (with antenna connected ,SWR 1.2) and the...
It would be very hard to diagnose the problem from just the informations listed. My experience is a radio that has been sitting will have problems with the electrolytic capacitors drying out and throwing the receive tuning way off. The capacitors are the small metal can looking devices on the board. There are a lot of them. The top of them should be flat. If one is rounded on the top it is often times bad. Of course it could be a transistor in the receiver chain. Just one bad one will stop everything. It could also be a bad solder joint. You can try pushing gently on different places on the board with something non-metalic like the body of a plastic ink pen. Flex the board slighty and see if you get a change in sound or you can hear other stations. If so, you have the delicate process of tracking down the bad joint and repairing it. Just lightly using a solder pencil to remelt joints will often solve this type problem. If you can't find it then it will take a technician with the proper equipment to track it down. Good luck.
Sep 24, 2013 | Cobra Radio Communications
I can recieve conversations clearly. I respond and it sounds like I am under water
The mic is probably your problem but...if your radio has ssb/lsb make sure your on am and the clarifier knob is in the center. Really need to know the specs and radio make ?
Oct 10, 2012 | Cobra Radio Communications
Cobra 19 DX IV out of frequency
I would definitely take it back for a re check. If the radio took a good bump perhaps it can cause it to drift off frequency. Turning the channel while holding his mic keyed does nothing but just throws a dead carrier. No value what soever. RF Gain is just to improve his reception by either lowering or raising the sensitivity of the receiver of the radio. Squelch is to silence the hissing sound you hear when no one is talking. Care must be taken to not to adjust too much or you wont hear anybody. It wont help his transmit audio at all. Recommend you get another Radio Check from someone else. He could be pulling your leg saying you don't sound good. Best regards and hope this helps some......................John.
May 27, 2009 | Cobra 19 DX IV CB Radio
No one hears me but I hear everyone else for miles.
check Your mic. Might need replacing. also with all the changes in the past few years check it out fully. If you can program it you might want to reprogram it. Hope that helps You.
May 24, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
I can hear people talking, but they can't hear me, or they say I sound like an alien
Check to see if the meter needle is swinging backwards when you key up. If it does your final may be bad. If the needle goes forward and others say they see your keying up but no sound your audio chip may be bad; especially if you have tried so many mics and antennas. If your radio has a swr warning light and it comes on this could extremely limit your range and others may not hear you and contiued use will damage your radio. Good luck!!!
Jul 26, 2008 | Cobra 29 LTD CB Radio
Cant talk through mic
Sounds like a bad or miswired mic. Try a new mic ( use the proper cobra mic ). If the problem still continues, check all the swiches on the front of the radio and make sure you don't have any cold solder joints ( broken lead to board connections ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 2000GTL
Hello wood butcher,
This sounds like a capacitor is not discharging fast enough and has enough residual voltage stored to continue to power the display (to a point). I would check the capacitors that are connected to the vcc of the display matrix and also check to see if one of the resistors has not increased in value due to a possible thermal event.
Tell me how this works out,
Thank you,
Shuttle83
Oct 30, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
689 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
