Machine-- with load suddenly washes ok-- but at times wont completely drain completely or fast spin.----ie complete the cycle its supposed to do
also will only slow spin at times on 'c' -- and not slow-spin on b
i am unsure as to if the problem could be --- worn brushes --- or programmer acting up --etc???.
nb ---- the above problem/s started suddenly -- with out prolonged signs that anything was not quite right---this as i feel worn brushes should give ---pre-warnings????????,
any ideas --etc
SOURCE: Hotpoint WF340 - wont complete programme
hi without looking at it i would think that the control board behind the timer knob has broken down these can quite pricey so shop around before you buy one,hope this helps.
Posted on May 15, 2008
SOURCE: Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Posted on Sep 24, 2008
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
SOURCE: washing machine after water load the drum
must check water level device,if You do not know what is this or where is on machine then call a service.Maybe is hose is precipitate from device.
Posted on Feb 17, 2009
your timer is most likely bad
Posted on Apr 20, 2009
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Jan 28, 2014 | Beko Washing Machines
Dec 03, 2012 | Washing Machines
May 17, 2012 | Beko Washing Machines
May 29, 2011 | Washing Machines
Aug 30, 2010 | Washing Machines
May 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Mar 28, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
223 people viewed this question
I have the exact same problems with my machineas above, these problems started on and off from the machine after the 1st 6months, onwards. Can anyone help
