Question about Haier BC112G Wine Cooler
Haier BC112G Wine Cooler will not maintain temperature
I can sometimes get the cooler to turn on by pressing the "set" button. When it turns on it runs until it achieves the desired temperature. Then it turns off automatically. But it never will turn on automatically. Hence, the only way to run the compressor is to turn it on manually.
  • Anonymous Jun 02, 2008
    I have it set at 55F, but it sits at 66F.  If I unplug it and replug it in, the compressor turns on and the temperature begins to drop.  Over the next ten minutes it drops steadily to about 52F (i.e. below the set point) and then appears to shut off, and after that it gradually heats back up to 66 or so.
    So the compressor seems to be working, but it will not cool to the desired temp.
    If I knew what part to replace I would gladly try to replace it myself...but I do not want to mess with the compressors!
    Do you think this is a thermostat? Is that the same as the temperature sensor?
    Thanks for any advice/
Same problem. I just replaced the sensor but the temp just keeps dropping . Its sitting at 28 degrees now !
I've looked for a thermostat but cannot find one .
Posted on Nov 14, 2009
For parts try this....
Posted on Jun 25, 2008
    Problem Solver:
  • 10 Answers
The temperature sensor should fix the problem. It usually a inexpensive part. Its wire runs from the display board on the top, to where the sensor sits behind the unit (obviously in the cabinet)
Posted on Feb 06, 2008
  • 833 Answers
I'm going to say replace the circuit board
Posted on Dec 21, 2007
It just stopt cooling (
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
How to adjust the temperature of the wine cooler
How is temperature adjustment set for proper cooling,my Haier holds [9] btls of wine ,please help.
Jan 05, 2011 | Haier BC112G Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts:
Dec 31, 2010 | Haier BC112G Wine Cooler
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
Can't change temperature
You press set button and then + and -, if that does not work, the stat is faulty.
Mar 09, 2009 | Haier BC112G Wine Cooler
Haier wine cooler freezes the wine.
You may find that the thermostat is not working. Try to turn the thermostat to the warmest setting, the compressor should switch off within two hours, if not change the thermostat.
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Nov 25, 2007 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Logo
841 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Haier Furniture Expert? Answer questions, earn points and help others
