Samsung HCN473WX/xaa This problem on model HCN473WX was fixed by a Samsung authorized repair center july 06((both IC's STK302040 on convergence ) - 1 month later the same thing happened - this time they took the set and held it for about 2 weeks - returned it and it ran fine for about 4 months- now the same problem is back. (out of warrantee). I have some experience in electronics, and took a look at the CG board and noticed a cluster of resistors that appeared to be burnt (RZ123,124125,126). Rechecked solder joints for IC's replaced and they look ok. Does anyone have the specks for this cluster of resistors.
  • err008 Nov 29, 2008
    Hi What is the solution to this proble..please help.
The tv shuts on and off by itself and the timer light flashes while doing so. I unpluged it for a couple of days and plugged it back in. The tv worked for about 5 hours and then it started shutting on and off again by itself.
Posted on Sep 21, 2008
How do i fix white dots on samsung tv hl-t6176s
Samsung is replacing this free of charge.
Dear Samsung Customer,
We apologize for the inconvenience you have experienced with your Samsung product.
Your request for service has been forwarded to an Authorized Samsung Service Center who will be in touch with you shortly and is tentatively set for an appointment on Feb 15, 2013 AM time window.
You can get real time repair status by one of the following options: You can also Chat with one of our agents to follow up with your service request.
Thank you for being a Samsung Customer
Sincerely,
Rajiv Mehta
V.P. Samsung Service Operations
Help make your service process smoother. Upload a picture or video of the issue you are experiencing by clicking here.
Service Type : Repair Warranty : Labor (08/31/2008), Part (08/31/2008)
Product Information
Model Number : HLT6176SX/XAA Serial Number : B32T3CKP601351Y Product Symptoms : Quality/Trouble/Video&Image/Multiple white dot on screen
Oct 13, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Help not sure
This maybe the problem why it is repeating. They didn't change all return resistors. they are different sizes all are probably smaller than 100 ohms. You will need the exact size and there are caps that maybe bad and maybe fuses also
Nov 25, 2007 | Samsung HCN473W 47" Rear Projection...
Another Question Please.
Horizontal lines can be cause by many things. One of which is the convergence module. $130.00 is a little high for something that can be caused by other things as well.
Jun 17, 2007 | Samsung PCN5425R 54" Rear Projection...
My sanding tv hlt4675sx xaa keeps turning off. When I turn it back on here a little grinding noise... now when I turn it on can here the fans come on nothing else. No light from the bulb is showing from...
It sounds like the color wheel has fallen apart. I would recommend calling Samsung at 1-800-samsung to find the closest service center. This can be a difficult repair and I would strongly recommend a Samsung authorized repair center.
Aug 01, 2011 | Samsung Televison & Video
My tv suddenly went to red and green double vision. Looks like 3D without the glasses. I want to repair myself. Samsung 1080i model HCR5245W. MFG July 2005.
That would be your Convergence, Encompass Parts Distribution
has Convergence Module for $50.00 that goes to a HCR5245WX/XAA 1-800-638-3328
Or you can just replace ICs will have STK on them
Mats has ICs 1-800-628-1118
Sep 27, 2010 | Televison & Video
Samsung, DLP TV 50 inches Model # HL-T5075X/XAA
Samsung just told me they wouldn't fix my tv because it was produced in Nov. of '06 and the only ones they would fix were made in August of '06 or earlier. I am way too angry right now to call the service tech number they so very nicely provided.
May 19, 2010 | Samsung DLP HL-P5663W 56" TV
Replacement color wheel for samsung 50'
I am having the exact same issue with the exact same TV. They no longer make that color wheel, so I am looking for a replacement part as well.
I am looking at the 01103A as well from here:
http://www.partstore.com/Part/Samsung/Samsung/BP9601103A/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HLR5078W
I think I might just order it, and if it doesn't work just return it.
Jan 15, 2009 | Samsung Televison & Video
Samsung rear projection television HCN4226WX/XAA
Dead Samsung
I don't recommend working on the TV unless you have some experience and knowledge relating to the safety issues and electronic repair. Most rookies will not successfully complete the repair and probably do more harm than good.
Sometimes when the convergence chips fail, the TV senses the changed load condition and shuts down.
Unplugging the blue, red or green convergence connector on the convergence board removes the overload condition if the IC is shorted and allows the tv to run, with one color missing.
This is done with the tv unplugged. Then plugged in and turned on to see if it starts. Turn off immediately if you here it start.
Now you know if convergence failure caused the shutdown. You can repair the convergence circuit if that is the problem.
If this has no affect, then you could have a number of different faults in Vertical output, Power Supply or HV circuits that require the expertise of a qualified service person. This would be a bench repair in most shops.
If you live around Calgary, Alberta try me instead:
http://calgaryconvergencerepair.weebly.com/convergence-explanation.html
Or try to the find the repairperson part of this website (on the Homepage) and search postal code. Maybe you will be lucky and someone from your area is listed for Projection TV repair.
Most rookies doing this job will cause damage and not be successful. They will pay double for someone to fix their mess or end up scrapping the TV. It is not a simple task. It is more difficult than batteries on a remote.
Good Luck
easyab
May 27, 2008 | Samsung HCN4226W 42" Rear Projection...
Double picture
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 06, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN473WX
you may need to do convergence to align the colors up.
the only thing other than the ic that need to be replaced are resisters and if the resisters are bad you would not be able to move one of the colors, and blow out the ic you just installed.
Nov 04, 2007 | Samsung HC-P4752W 47" Rear Projection...
Televison & Video Logo
340 people viewed this question
Top Televison & Video Experts
