Question about Philips Magnavox 51MP392H Rear Projection Television
Power failed - lost tv
Power failed today for approx. 45 seconds ... lost tv picture ... hear a chirping sound when we turn it on
  • 1,153 Answers
No high voltage. probably convergence amps.
Posted on Nov 26, 2007
T.V shuts off and power light blinks.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 21, 2017 | Sharp LC-32SB23U 32 in. LCD TV
Rca hd52w59 chirping sound and light 3 times no picture
chirping sound is a short of some kind, could be the flyack or horizontal output, could also be a bad picture tube or power supply capacitors, you really need a tv repairman to troubleshoot this.
Sep 17, 2009 | RCA R52WM24 52" HDTV Projection Television
Kdfwe42655 Sony Picture on approx 45 seconds; <try this and good luck! let me know if it helps...
Jun 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have the 55" phillps rear projection tv
Common problem with this model. Goto to get their chirping TV repair kit.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
My tv has a dinosaur in it.
Its a raptor most likely. But seriously, when these RCA TVs go into shutdown or fail to power up, they will try 3 times to re-establish operation. Your problem can be caused by a number of circuits. The power supply itself may be bad or the high voltage/ deflection circuit. You can visually inspect the circuit board. Some failures in these TVs will cause obviously damaged components like burned resistors and the like. The problem here is that most anything that will fail will cost some serious money. Expect to spend $300-500 to repair it or consider replacing it.
Feb 15, 2009 | RCA D52W19 52" Rear Projection Television
Power failure lost tv
The chirpping noise is significant, it means that the smps is loading down because of a direct short, possibly in the horz. output transistor. But that is most likely not all the problem or the damage. It wasn't losing the power that hurt it was getting it back and the power most likely spiked with enough of a surge to damage the LSB (Large Signal Board)... I've seen at least a half dozen of these in the last six months with the same scenerio and the only repair for this is to replace the LSB, unfortunately they are no longer available so the next best thing is to have it rebuilt.
The part number of the LSB is 313503712571 and at Vance Baldwin they're $353.00 with a $30.00 core plus shipping. You're better off having the shop tear it down and send the board directly into PTS Electronics. At least you've got a rough idea what you're facing..
Hope this helps!
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Aug 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
Green Power light blinks but no picture or sound with a chirping noise
That chirp is your ballast trying to fire the lamp. Sounds to me like you need a new lamp. The model should be TY-LA1000. Keep in mind though that the ballast could also be faulty, but 85% of the time it's a lamp. Pull the cover off the unit and remove the lamp. More often than not, when the lamp goes it'll actually break and be obvious.
Dec 12, 2006 | Panasonic PT50LCX63 50" Rear Projection...
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
