Monitor doesn't display any information. All hookups are in tact.
While it is still power on, unplug it from the video port of your computer. Can you see anything on the monitor? If so, the problem is with your computer. You need to troubleshoot. First try the monitor on another computer and verify that it's working fine. If it's not, then ask for repair and if it would cost some around $200, I don't recommend, you'll get a bigger and better new monitor for $200.
If you think there's nothing wrong with the printer and is tested ok, then start working with your computer, first try with another monitor and boot up, probably it shouldn't work, if it does, then the cable you were connecting the other monitor must be the faulty.
The best thing you can do with a dead video computer is to re-seat the Rams, Power connectors and Bios battery. First remove the Ram/s and boot again, you'll hear the beeping, means there's no ram installed. After cleaning the ram, again install it/ (if there are multiple rams, install only one), now boot again. same problem, try again with the other ram.
If you see no changes while working with the rams, then it must be the bios or the video card itself. If you have a spare graphics card, try it or if you don't have one, then the only solution is to replace the motherboard.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
