Question about Magic Chef Refrigerators
My magic chef portable ice maker does not freeze ice cubes. Water flows in like supposed to and try dumps just no ice.
    Habit-Forming:
  • 23 Answers
Freon is leaked out or the compressor is not working..
Posted on Oct 02, 2018
HVACRH20
  • 237 Answers
SOURCE: Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
Posted on Nov 09, 2006
Master_Tech
  • 770 Answers
SOURCE: Frozen slabs of ice instead of ice cubes
the icemaker could be leaking by can you see where the water is coming down into the bin from??
Posted on Jan 24, 2008
My lady friend has the same problem with her ice maker. The problem is, the ice tray is broken on the end. I took her ice maker out and found out it was broken. Its going to be hard finding a replacement since they don't make parts anymore.
Good Luck !!!
Posted on Dec 02, 2008
  • 64 Answers
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Posted on Aug 26, 2009
SOURCE: Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Posted on Oct 14, 2009
Suggest me a best portable ice maker that comes with three select able cube sizes?
You can get Ivation Portable High Capacity Countertop Ice Maker that comes with 2.8 liter water reservoir, 3 selectable cube sizes - yield of 26.5 pounds of ice daily. As this is one of the best portable ice maker that one can get for getting the best options for oneself. Also, this is best because it is made with many best features that are best for providing one with many benefits for the overall health of the body. You can also get many different options also that are available and you can purchase them after comparing them from Best Portable Ice Maker
Apr 01, 2017 | Refrigerators
How do you put water in the magic chef model number mcim22sv portable icemaker?
Remove ice bucket and add water to fill line at the back of the water tank
Jan 17, 2013 | Magic Chef Portable Ice Maker
Ice maker will not dump ice
water freezes at 32 deg the ice mker works at 15 deg or lower . ck the tempts in freezer . if the freezer is lower than 15 deg the icemker may be at fault . .. mm hope this helps .. feed back pls .
Jul 09, 2011 | Magic Chef Refrigerators
My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
Jun 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice Ice maker does not fill up with water
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then check the fill tube going to the ice maker , to see if it is frozen up inside . If it is , replace the water valve behind the refrig , where the wall water line connects to on the refrig . If the ice maker dumps the cubes , but does not refill with water , then the water valve is bad . If the ice maker does not dump the cubes , then replace the ice maker .
Nov 11, 2009 | Refrigerators
Ice maker will not make ice
Make sure the ice maker is turned on ( green light ?) . Pour about 2/3 cup of water into ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the dual water inlet valve ( one coil for water dispensor , the other is for the ice maker ) . If it does not dump the frozen cubes , then replace the ice maker .
Sep 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Magic Chef Ice Maker Model No. MCIM30TS. My problem is that when I plug it in, nothing happens and the power light is blinking. Is the unit shot? Andrew from New Jersey
Hi, It's supposed to do that. Fill the base with water, then select an ice cube size, then click "start". It should start making ice within 20-30 minutes. The power goes off here all the time and that's how we re-start the machine. The important part is to first select the ice cube size, then click on "start'. I have no idea why it has to be done in that sequence. I have the same model, only I got it two years ago.
Apr 26, 2009 | Refrigerators
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Refrigerators Logo
191 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
