OTHER FEATURES Tab
To set a tab, move the carrier to the desired position and press the key. To clear a tab, move the carrier to the tab position to be cleared and press
the + key.
To clear all tab position, press the + key for half a second.
Centering
Your typewriter allows you to automatically center a line. 1) Press the + (CENTER) key.
The carrier will move to the center position between the left and right margins. 2) Type the text. The carrier will be backspaced half a space.
CODE
3) To print the text, press the ,
4) To cancel centering mode. press the
to the center position.
Decimal Tab
Decimal tab allows you to align numbers by decimal point at the tab position. 1) Press the + key.
The carrier will move to the next tab position.
2) Type the text. The carrier will be backspaced one space.
3) When the decimal point (.) is typed, the text will be printed out with the decimal
* If you make a mistake, press the
or
key.
Pressing the + key will erase the whole line and move the carrier
point.
4) To print the text, press the ,
5) To cancel the decimal tab mode, press the
to the position where DECIMAL TAB mode is entered.
or + key. key.
+ key.
* If you make a mistake, press the or
TAB C
CODE
9
RETURN
TAB
or
key.
+ key.
CODE
DEC TAB
TAB S
CODE
TAB C
RELOC
X
CODE
WORD
CODE
WORD
CODE
DEC TAB
RETURN
X
TAB
CODE
DEC TAB
RELOC
CODE
WORD
CODE
WORD
11-10-
SOURCE: Smith Corona WordSmith
Go to: http://www.smithcorona.com/Customer_Service/Manuals.cfm and print a manual. Page 7 should provide your fix.
SOURCE: How do I adjust margins on Smith Corona WordSmith 100?
Return to the L. margin Press code and 1 release kets backspace to where you want L. margin press L mar key.
DickyO
SOURCE: smith corona wordsmith typewriter model # ka13
The print head might have accummulated a lot of paper bits you need to clear them with a needle or just submerge the tip in petrol or ether. Caution do not submerge if its made of plastic.
SOURCE: How do you adjust the margins on a Smith Corona
Go to brother international.com, ck\lick on support, poke around there, you should find a manual.
DickyO
