Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I can only hear some of the audio output on my dvd player. we were watching a dvd and thought that it was the dvd itself, but unfortunately, it wasnt. we can only hear some of the voices, and not others. it sucks to use subtitles... is the player shot, or is it just wire issues??
  • 1,153 Answers
Re: DVD SOUND ISSUES - Mitsubishi WD-52525 52" Rear Projection HDTV Projection Televisions
Do your tv works fine without dvd?
Posted on Nov 29, 2007
0 characters
3 Points
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Hooking up my DVD player to my TV and get sound but no video!
dvd player yellow output into
tv yellow input
dvd player white output into
tv white input
dvd player red output into
tv red input
if still no pic replace cords
Dec 31, 2008 | Projection Televisions
Hi,have 32" lcd hd tv with built in dvd player,model lct32z4adp... no sound when playing dvd.
Locate audio output ic and trace to dvd unit. Look for open circuit. possible dvd audio out chip bad.
Oct 02, 2008 | Akai Projection Televisions
Connect to dvd player
On the back panel of your tv you will see two audio inputs labeled AUDIO TO HI-FI. Plug your surround sound audio jacks, ( red and white ) into that. Plug your video jack ( yellow ) into what ever number input you are going to use for dvd, if needed. This will allow you to watch tv and hear it in your surround sound. You should also go to menu- then- audio option and turn off your tv internal speakers, this will allow your tv remote to control your volume of surround sound. Hope this helped.
Sep 07, 2008 | Hitachi 51F59 51" HDTV Projection...
Toshiba 52hm95 DLP HDTV - no sound
What cables are you using? Some TV's and DVD players have options to set your audio source. My DVP5982 I have to set it to HDMI digital audio, check to see if you have that on your TV.
Jul 04, 2008 | Toshiba 52HM95 52" HDTV Projection...
Dvd plays can see picture but no sound
Check all your connections.
Also please let me know how you have it connected currently, what is the model of the dvd player and the television. Are you running through an AV receiver?
one ting to try is connecting ONLY the red and white audio connectors from teh dvdplayer to the correct input on the tv while it is on. if you hear a slight "pop" [not harmful] you have the right input and there might just be a problem with the dvd player itself.
be sure you have the right audio track selected or try playing a cd.
May 02, 2008 | Projection Televisions
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Projection Televisions
I am trying to hook up my tv to my receiver, I have a dvd vcr combo,and cable box
Audio: There should be a set of audio outputs on your TV. Connect those to the AUX inputs of your receiver. When you turn on your receiver, set it to AUX. Set your TV volume to approx 1/3 and adjust the volume on your receiver. There's probably a menu section on the TV to turn off your TV speakers so the sound will only come from your receiver.
DVD/VCR (I'll call it DVD from this point forward): Connect the video (yellow) output from the DVD to the "video input" on the back of the TV. Connect the audio out on the DVD player (red) to the red audio input on the back of the TV, then do the same with the other audio (white). When you want to use your DVD player, you'll select "input 1" as the input on the TV.
Cable: Your cable box probably has numerous output types. I have the cable box hooked up to both the DVD player AND to the TV; one output type going to the DVD player and another output type going to the TV. I like to use the HDMI output from the cable box to the TV, and the composite video from the cable box to the DVD.
Hope this helps. Let me know if you need more info.
Mar 18, 2008 | Projection Televisions
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
27 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
