Question about Toshiba Satellite A85-S107 Notebook
I think its my battery
I use my computer and randomly it will have the battery drain while plugged in. It says on the computer that it is plugged in but it is not charging the battery. If i turn the computer off and take the battery out and put it back in, it works fine. This has been happening more frequently. Does this mean I need a new battery???
  • 324 Answers
It might be the battery or battery contacts, but sounds more like a problem with the a/c adapter cord being bad at the connector that goes into the back of the pc. Or, the power jack on the back of the pc may be loose, or damaged.
Posted on Nov 26, 2007
Battery drain
Remove the fuse for radio. The tape player should stop clicking. Then try to see if the battery dies.
Apr 14, 2014 | 2006 Acura TL
Glitching tablet
I'm guess here that you have had the unit for some time? If you leave it plugged in all the time you can actually damage the batteries. Any battery powered (rechargable) device should have the batteries drained periodically to condition them to last longer. My guess is the battery is not holding a charge properly and giving spikes. You can take to battery store and have it checked or if you have a ohm meter you can check for yourself.
Mar 03, 2014 | ZEEPAD Audio Players & Recorders
I have a 1982 tioga arrow that I just bought and the previous owner had rerouted some belts between the time I test drove it and the time I picked it up. This caused it to overheat on my way home and I had...
Over tightening belts flogs bearing and bushes as too much lateral force is applied.
Re-routing makes me think it's not driving the water pump.
Lastly YES the horn can drain the battery as it can short the plates inside it
Apr 16, 2017 | Cars & Trucks
My 2001 Chevy Suburban won't start at times. I remove the cables from the battery and put them back on at it will start sometimes. Other times it requires a jump. It's random. I also noticed...
your battery is being drained ,, check the plug in for the towing light hook up , something is shorted across ,, clean and tighten all connections to the battery ,, once the vehicle is running,, check the posts with a meter, you should get a reading of 13.5-14.5 volts, if not your alternator isn't doing its job
Sep 03, 2011 | 2001 Chevrolet Suburban
I have a Satellite A215-S4807. The original battery went completely dead (possibly from this problem), so I just went out and got a new one with a 4800mAh, which is slightly higher than the 4000 it came...
There is something wrong with the "recharger" components on the computer's motherboard.
Instead of charging the battery, and then stopping the charging process, it is "draining" your batteries.
Take your Toshiba to the nearest qualified Toshiba service location, to get it fixed.
Aug 26, 2011 | Toshiba Satellite A215-S4807 Notebook
When sitting idle, my pearl lights up randomly. i
Try this Hold down the ALT key, and press right-hand CAP key press the DELETE key aswell together which resets the blackberry
Have you installed any new application?. Bcoz this is happens due to new application (themes).Please delete the particular application and check.
Nov 16, 2009 | RIM BlackBerry Pearl 8100
My parking lights will randomly turn
I think the problem may be from a couple of areas. Check the fuse box that controls the light in the engine. It may be a bridge or contact problem. You could check the integrity of the light switch for any fault.
Sep 10, 2009 | 1999 Chrysler 300M
Battery goes dead randomly ,other times starts right up
I had the same problem, every 3-4 months the battery was dead. Found to be the computer staying in a self diagnostic mode that was slowly draining the battery.
Oct 21, 2008 | 2005 Kia Sorento
Random shut offs
Sounds like a faulty battery, these phones arent known to have very good battery life even when they work properly
Nov 22, 2007 | HTC S620 Smartphone
Toshiba Satellite A85-S107 Notebook Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
