Question about Maytag Washing Machines
Maytag centennial washer topload does not wash or rinse but spins. Any possible solution?
    Sergeant:
  • 168 Answers
first check the belts look under the machine maytags used to have two belts. if theyre slipping then your going to have to figure out how to re tension them. hopefully its the agitator cams. your going to have to study how your agitator comes apart, inside the agitator are a set of one way cams, usually the cap comes off and the cams are down inside. if the agitator does nothing at all with the belts are present then transmission or computer or timer failure. Maytag Washer Agitators Replacement Parts Accessories PartSelect
Posted on Oct 01, 2018
SOURCE:
  • 77 Answers
SOURCE: Maytag Washer - Discoloration on Clothes
hi, i think your stains are grease from a failing drum bearing, it is a common problem, the bearing needs to be changed, hope this helps, thanks for using fixya
Posted on Feb 15, 2009
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
dh1200s
  • 335 Answers
SOURCE: maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test
to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Posted on Sep 17, 2009
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
TheMobilian
  • 8220 Answers
SOURCE: My Maytag topload washer is
That may just be a worn out belt. It's pretty easy to replace. Tip back the washerthemobilian_1410.jpg
With belt off turn the pump. It should be pretty easy to turn by hand. Finally if the belt is good and pump is fine then you might have a bad main drive pulley or a badly worn one. The pulley releases the tub for spin. If the pulley is worn out it won't release well and the clothes will be soggy.
I have more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 10, 2011
Testimonial: "Very useful and great advise"
My washer wont rinse. It seems to have a hard time spinning, any suggestions?
do you hear the motor running ,it will drain but no spin,this has no belt in it it's built just like a whirlpool washer because whirlpool owns maytag now and this washer has a motor coupling,i would check this first,do you know if the agitator is working or do you hear a grinding noise when it's running?watch this video and you don't have to disconnect the wire harness to the motor if you don't want to,i don't just put motor off to right side still connected
http://www.youtube.com/watch?v=9K1KHEogf3c
Apr 09, 2013 | Maytag Centennial MTW5800TW Top Load...
My Maytag Centennial Washer is a top loader. It washes fine, but will not spin out after the rinse cycle.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jan 21, 2013 | Maytag Washing Machines
Washer wont pump water unless in spin cycle
it is not supposed to pump water unless it is in the spin cycle. On most topload washers the motor turns one way for the agitate cycle and then the motor reverses during the spin/rinse cycle which in turn reverses the pump and causes it to pump the water out.
Oct 28, 2010 | Maytag PAV5157A Top Load Washer
Washing Machines Logo
114 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
