SOURCE: pioneer deh-p3500 memory wire color
12V Battery, Memory/Constant wire Yellow
FYI:
12V Accessory Wire Red
Ground/Chassis Wire Black
Left Front Speaker, Positive (+) White
Left Front Speaker, Negative (-) White w/Black Stripe
Right Front Speaker, Positive (+) Grey
Right Front Speaker, Negative (-) Grey w/Black Stripe
Left Rear Speaker, Positive (+) Green
Left Rear Speaker, Negative (-) Green w/Black Stripe
Right Rear Speaker, Positive (+) Purple
Right Rear Speaker, Negative (-) Purple w/Black Stripe
Remote Out, Power Antenna Blue
Remote Out, Power Amplifier Blue w/White Stripe
there is only one power wire i cant remember the color use a test light to figure it out...then you need to make a wire off the fuse box that turns on when the ignition is on
SOURCE: pioneer car stereo instalation
if they are all positive speaker wires then each speaker will get a positive and the other speaker wire goes to the ground of the ground wire
SOURCE: color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
SOURCE: Need color codes for car
2001 Pontiac Aztek Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
