Question about Philips 55PP9701 55" Rear Projection Television
Scrambled picture horizontally
Only on the #4 and #5 video my screen scrambles the picture horizontally. If I go to video 1,2, or 3 its fine. Any help would be appreciated. Thanks.
  • 1,153 Answers
Re: scrambled picture horizontally
Is this HD on 4 and 5 then it will do it if you don't have a HD signal.
Posted on Nov 26, 2007
0 characters
3 Points
Picture colors scrambled
Ur convergence it dead,Know how to solders?Buy a convergence kit to repair.These websites have the kit.Tv repair,Tv Repair Kits.
Dec 12, 2009 | Toshiba 57H82 57" Rear Projection...
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Samsung HLP5063W 51 inch DLP is 4 years old. Screen scrambled?
there is a complete section in the tv that translate the different resolutions from the different out side video sources you normally use to the TV native resolution. That area has to be replaced. Is a module repair needed. Don't get scare. now days this kind of repair is normal and has to be included in the repair price to see if is economical to repair.
Mar 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Mitsubishi ws-55813 horizontal hold
When you say horizontally, do you mean it collapse or it scrambles. Because the 2 are different problems. If you pictures shrinks or collapse then it is in the vertical circuit. and if it scrambles itself almost like you can see the picture but it is broken up over and over again, then this is video problems in video circuit. Need more info
Aug 13, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Coaxel and composite jacks produce scrambled picture, componite ok.
Bad hyper board = repair by qualified tech, PCB not available...
Feb 11, 2007 | Toshiba 50HX81 50" Rear Projection...
Philips 55PP9701 55" Rear Projection Television Logo
113 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
