1994 Mitsubishi CS-35303 TV won't turn on
This is an extra set we've had for a while. It spent some time in the garage (6 months), because the picture was "squished", with black bars top and bottom, none on the side though. When I got around to messing with it, it will not turn on. I plug it in, and it clicks, like it is powering up, and the screen flashes white, and it instantly goes off, and instantly retries to power up, clicks, white flash, off, clicks, white flash, off. This continues until I unplug it. Power button does nothing. Once, it actually came on and stayed on, with the "squished" picture, but worked fine, until I turned it off. Then the click, white flash, off, started over. So, I know it is old and may not be worth fixing. But I am going to try (it belonged to my wife's dad), so any advice would be very helpful. I have electrical experience, and all the safety tools, and what have you. I am just lacking schematics and manual. Thank you for your help.
  • jerrid757 Nov 26, 2007
    Troylove, Thank you very much. What do you mean?
    Genius:
  • 1,153 Answers
Vertical IC and Cap.
Posted on Nov 26, 2007
Picture takes 10-15 sec to come on after setting all night. Sound is OK.
If this has been taking longer to come up over time, it is likely the picture tube at fault. Time to look into a new set.
Jun 25, 2014 | Mitsubishi CS-40503 TV
CS-35303 tv picture reduced down to a line horizontally through screen
The set weighs a ton so getting inside is first challenge.
Problem is in vertical circuit--9 out of ten times bad solder connections on the vertical output IC---usually if rapped on the cabinet the picture may try to open up.
The chip will have a location number like IC301 or 401 and if memory serves me be a LA7845 with that or a similar LA number right on the front.
If get to it only 7-13 pins (depends which chip is used) in a straight row--look at the solder connections on them--if find any that look a little discolored or even cracked solder all the pins.
picture of what a typical chip looks like:
the actual number will be right on the face of the chip12_21_2012_9_31_45_pm.jpg
Dec 21, 2012 | Televison & Video
What is the code to unlock my mitsubishi CS-31303 tv?
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
Jun 25, 2012 | Mitsubishi Televison & Video
Color adjust without original remote cs-35303
Almost any Mitsubishi remote will work for standard adjustments--just that simple.
If issue is too much red, green or blue(not a good black and white picture) the controls for those adjustments are located inside the set on the board that plugs onto the end of the picture tube.
Let me know what your issue is and I will advise further.
Mar 20, 2012 | Televison & Video
I have a Mitsubishi CS 3515R 35" Tube TV. The screen has narrowed at the top and the bottom so only about 2/3 of the horizontal screen has picture. There are black areas at the top and bottom....
There are two issues, the first is a vertical deflection problem, "needs a few parts+an ic" the second problem is intermittent color, "crystal and color processor ic" If the set is close to 10 years old then your money is better spent on a new tv.
Mar 20, 2011 | Mitsubishi CS-35503 TV
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
Cs-36509 mitsubishi tv has a flicker.Makes it hard to read words. Is real bad when you first turn the tv on, but after a minute it settles down, but is still there all the time... any suggestions?
Yes first it may just be bad solder on the
flyback transformer , or the Picture in Picture
module has some bad caps . a fair shop
price is about 180-200 and it worth the repair
they are great TVs and are made to last.
ps i have repaired my mitsubishi once , and
its going strong. 18 years old .
THE OLD STUFF IS BETTER THEN THE NEW STUFF.
Mar 25, 2009 | Mitsubishi CS-36509 TV
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS 40503
it is repairable and can be fix,,
Jul 30, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS-27205 shrunken picture
Good set...worth repairing vertical circuit.....in shop...
about 100.00........................T.
Nov 15, 2007 | Mitsubishi CS-27205 TV
Televison & Video Logo
354 people viewed this question
Top Televison & Video Experts
