Question about RCA P50830BL 50" Rear Projection Television
RCA P50830BL will not turn on
1998 RCA P50830BLwill not turn on.was working fine one day and the next no power.checked power cord,there is power present.any solutions would be great.
  • 1,153 Answers
Re: RCA P50830BL will not turn on
You have a shorte chopper diode, on main board look in middle of BD. You will need to change Horizontal output and Block blue caps and big Diode.
Posted on Nov 26, 2007
0 characters
3 Points
Rca p50830bl manual
type the rca p50830bl manual on search engine and download the manual
Jul 18, 2013 | Projection Televisions
My Tv was working fine for 10yrs then one day i try to turn it on and nothing happen...I heard 2-3 clicks and nothing else. ( NO PICTURE OR AUDIO!!!...This Tv has been great to me over the years, The...
try to look for the power supply area, it is found on where the main plug is connected check if there are busted fuse of shorted parts,, the "clicks that you heard are the relays. relays are loosing out of supply because of a shorted parts like transistor or diodes or sometimes loose connection. Parts description are found in for you to know how to test the parts that u suspect
Jul 20, 2011 | RCA P50830BL 50" Rear Projection...
RCA 50" - Convergence problem and now "Popping" + no picture
The high pitch popping that you are hearing is arcing in the high voltage circuit. I would not suggest a repair on a set that is this old. Convergence repair plus a high voltage problem could run around $500-$600. But it is your call on the repair, I can only advise.
I hope this helps you.
Thanks for using FixYa
Sep 23, 2009 | RCA P50830BL 50" Rear Projection...
Blowing fuses p50830bl
the board mounted overtop the of the chasis is the convergence power supply board
replace that board will bring your tv back to life
then go into menu readjust convergence red and blue DO NOT MOVE GREEN
Sep 01, 2009 | RCA P50830BL 50" Rear Projection...
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
Apr 25, 2008 | RCA P52926 52" Rear Projection Television
RCA P50830BL
Hi,the trouble is the power supply for the convergence,it the board that mounts above the two board that lay flat,there is a ic on that board that is heat sinked,part number is 215530,replacing this ic will return the menu and repair the set,the board is green 5 inches wide and 8 inches long.
Mar 13, 2008 | RCA P50830BL 50" Rear Projection...
RCA P50830BL 50 in.
This is burn in on your set. Something that had those words set on your set for too long. There is no solution to this problem replacing the CRTs would not be cost effective...make sure you do not leave any still images on your tv for extended amounts of time.
Feb 04, 2008 | RCA P50830BL 50" Rear Projection...
Remote not working with P50830BL
Yes it certainly could be a problem with the remote sensor assy., as I have had bad ones from rca in the past, But mostly its been bad connections from board to board or a jumper or even a few times the Microprocessor IC was bad. The best and only way I know to trouble shoot this, without shotgunning part after part and may get lucky, is to scope out the data line comming out of the sensor while hitting a function on the remote. If theres no data comming out then check the b+ going to the sensor also. Trace the signal all the way to the processor. If signal does make it all the way there , then of course the processor is the problem. Now theres High voltage inside these sets, so its not advisable for a handi-persomn to fix this set themselfs. There really are no user serviceable parts inside these sets as they are all soldered in and you need speacial equipment to properly work on most if not all sets these days. I would say a fair repair cost for a problem like this I would estimate at from200 to 350 depending on the exact problem. Good Luck
Jun 27, 2006 | RCA P50830BL 50" Rear Projection...
Projection Televisions Logo
138 people viewed this question
Top RCA Projection Televisions Experts
The Wyzzyrd
D. E. Hev
Ron Dufek
Ron Dufek
Are you a RCA Projection Television Expert? Answer questions, earn points and help others
