Question about Panasonic TC-15LT1 15 in. EDTV LCD Television
Fade from light to dark screen
Television picture suddenly fades / flickers from light to a darker screen...any thoughts as to what the problem might be. The TV is 5 years old and is on for about 2 hours per day. Is it worth repairing?
SOURCE: red power light flashing but no picture
Ditto for Jan 13th with a Panasonic 50"!
Posted on Jan 14, 2008
SOURCE: TV Won't Turn On
I purchased the TV using AMX card 18 month ago. They have an extended 1 year warranty on top of manufactory's. I just have this set repaired: replaced SD board, total charge is $550. I already file a claim and hope to get reimbursed soon.
Posted on Mar 06, 2008
  • 367 Answers
SOURCE: Panasonic plasma
If you open the back,look at the can shaped items.If any of them have the tops bulged out,they need to be replaced.This should solve your picture problem,unless there is something else wrong.What is happening,is they are heating up,and the picture goes out.I bet the longer you have the TV off,the longer it stays on?Hope this helps.Thank You very much! Tyler
Posted on Apr 07, 2008
  • 8457 Answers
SOURCE: LCD TV has dark smears on picture
This not repairable,it a LCD screen have minor pixels cracks in the LCD screen itself,some body hit the LCD Screen with somethings.
Posted on Jan 12, 2010
  • 144 Answers
SOURCE: My TH-50PX70A Plasma TV, has
The most likely issue is that the Power Supply has burnt out, you were able to let it cool at get it to work for a while, but perhaps part of the board has melted enough to cause a short. Repairs will cost approx. $300-500.
Posted on Jan 13, 2011
Testimonial: "ThankYou"
  • 45 Answers
SOURCE: i bought a panasonic pt-50lcx7k tv. i press power
theres a problem on the board of the tv set jsut go back to the service center for further check up of of the technician of the panasonic un plug the tv set for it can cause further damage
Posted on Mar 25, 2011
0 characters
1 Points
Please provide the model and make details
Apr 08, 2008 | Sharp Aquos LC-PD50U 50 in. Plasma...
Tv picture fades in the dark
Menu - Picture - Energy Saving
Various settings including Off.
Sep 27, 2014 | LG Flat Panel Televisions
Half of my 47" LCD Phillips screen fades from normal to dark. Any thoughts?
If it\'s a backlight issue one section will be dim and will fade darker or lighter to the other section. It is not a hard on/off line. So if it does fade to dark on one side I would suspect either a faulty backlight bulb (non-replaceable) or a failing backlight inverter (can be replaced.)
Jan 07, 2014 | Philips 47PFL7422D/37 Television
Check its back light inverter board and back-light CCFL lamps.
May 21, 2013 | Element Electronics Flat Panel Televisions
My screen keeps getting darker
This is probably the back light going out. They have tube lights in them and they do fade. You might notice the picture getting yellow too. This is not something that you can repair yourself unless you know electronics.
Sep 09, 2012 | Nexus NX4203 TV
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
you may have just put it into fade out. find thee fade out control and reverse it the mode. hope that works.
Apr 11, 2009 | Flat Panel Televisions
Picture is green and fuzzy in shaded areas
I have only see this issue caused by either a defective main bd. or a defective A/V bd. I am sorry but both would require a new bd and no simple repair exists.
Jun 18, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Panasonic TC-15LT1 15 in. EDTV LCD Television Logo
96 people viewed this question
Top Panasonic Flat Panel Televisions Experts
Are you a Panasonic Flat Panel Television Expert? Answer questions, earn points and help others
