Question about Frigidaire GLTR1670A Front Load Washer
Frigidaire GLW51439FSO top load
When washing drum turns slowly, agitator moves slightly one direction, machine knocks loudly, does not spin empty completely. Suspect family member over loaded. Machine is less than 1 yr old.
  • 447 Answers
It sounds to me like the belt may have a bad flat spot in it? This may be why its knocking loudly. Lift the top by using a putty knife to release two clips holding top down insert knife between top and front panel. Once top is raised remove 2 Phillips screws on bottom of front panel. Remove front panel. Now you have axcess to inspect the drive system. It is normal for the spin tub to rotate in increments in agitaiton. If it actually spinning around in a smooth motion, this is not right. When you say it doesnt empty completely?? Is there water left in the tub?? If so inspect drain pump for any blockages. PLease message me back for further help.
Posted on Nov 26, 2007
  • joey  shearer
    joey shearer Nov 26, 2007
    It is confusing wether you have a front or top loader. I believe it to Be a Frigidaire front load washer that has no brakes and a seperate electic drain pump.
  • 213 Answers
If the washer was overloaded it could have burned the belt which is most likely problem. or it could have damaged the transmission. if its less than a year old your still under warranty. you should call frigidaire. there should be a 1800# in your owners manual.
  • 290 Answers
This sounds like a more serious problem than you will want to tackle since it is in warranty. You should have a full one year manufacturers warranty. I suggest you contact the manufacturer and get a call set up. Calling the store you bought it from is usually useless, unless they service what they sell.
It sounds like you have a transmission or brake problem from what you describe.
  • Michael  Lindley
    Michael Lindley Nov 26, 2007
    I think your model number is actually
    GLWS1439FS0
    I see you have already recieved an answer to your problem.
    Thanks for using fixya.com
    Mike
  • 4,102 Answers
Have you had the back of the machine off if you know how to do this take back off and then try washing machine have a look to see if the belt is slipping on the drum could be that either the drum bearing has gone or that the motor has been overloaded and needs replacing also could just be the belt first of all i would take the back off and then try machine look where the belt goes from motor to the drum check if it is slipping if not slipping open the front door and try turning the drum by hand to see how much resistance there is on the motor shouldnt be to much after you have done this let me know the outcome and i will assist you further ok ill do all i can for you but remember i cant see what your seing so you need to explain in as much detail also other experts will see what you are saying and will also offer assistance but we need as much input from you as poss ok let me know
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Front loading washing machine makes loud knock on spin cycle
Move the empty drum by hands upp and down listen for noise, drumbaring my have been worne. Or is there some loose outside drum?
Feb 08, 2018 | Kenmore Washing Machines
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
Jul 09, 2017 | Maytag Atlantis MAV6260AWW Top Load Washer
Won't spin,changed drive belt, motor pulley and other pulley's are free to move? but belt just stays there with out turning any thing?
can you turn the center transmission pulley in BOTH directions it turns one direction to agaitate and the other to spin if it turns and someone looks in the tub and ever be it slowly it agitates and then turn the pulley the other direction and it doesnt turn the tub bearing is ceased up
Aug 10, 2011 | Frigidaire GLWS1349A Top Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine Frigidaire GLW51439FSO TOP LOAD
Your door switch will cause this problem not locking it.
Nov 27, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
70 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
