Question about Hitachi PJTX100 Multimedia Projector
Switching inputs I can't seem to find the way to make it so my my projector will automatically change the type of input when i change it on my receiver. I.e. dvd and component, digital tv and s-video, ect. I'd like to be able to do this without having to change each peice of equipment seperately. Thanks, any info would be great.
  • 115 Answers
Change the input selection from AUTO to normal. that will work
Viren
Posted on Nov 27, 2007
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
LG PA70G led projector turns off automatically :(
I had the same problem .
Take off all the Inputs
Switch to another input like USB and play the projector for a while.
Then reconnect the inputs back.
This worked for me ..
Jan 24, 2013 | LG PA70G Ultra PortabProjector
Vpl-cs2 Projector boots up and displays "S-Video" as the input. It will not let me change the input. In fact none of the buttons on the machine (or remote) seem to do anything. The projector...
remove all input signal connections.
Cover with a cardboard box to keep stray flourescent light off the IR sensors.
see if it starts up as before.
Apr 09, 2011 | Office Equipment & Supplies
Hi there, I'm trying to play a VSH/DVD through my
This happens when the computer signal is being used as the input, and the signal disappears or is the wrong type.
It may have tried switching inputs if you were using the video input rather than the pc input.
Press the auto image button to get it to select the correct input.
If you are using the PC as the dvd player, then change the display settings ie computer screen refresh rate, and resolution to suit the projector
Apr 06, 2011 | InFocus IN26 Multimedia Projector
Went out of town yesterday, hooked my canon 5210 up just like I always do, and got no response from the macbook. Luckily there was another projector available, and it worked. Seems to be the projector, not...
My problem didn't get solved, but my frustration was that I got a technician online two or three times, but couldn't post a response! The program wouldn't accept any input from the computer! So I was muted!
Jun 24, 2009 | Canon LV-5210 Multimedia Projector
How do i connect more compponents to my projector
The projector came with three video cables, and one audio. The first of the video cables is for component (three colors, which are blue, green, red) and is used for HD (hi definition) components. The second is an S-Video cable, which is used for just that, S-Video, which is one step below HD. The last type is composite, which is used for regular input. It has one input, which is yellow.
In order to utilize more than one component, you have to have a switching device. Since it is impractical (for me, anyway) to constantly unplug one video cable on the Cinego and plug in another of a different type, you must ensure that all of your components are of the same type. You may convert somewhat between components using cable adapters, but can only do so when the conversion is one level. The levels, from highest to lowest, are thus: HD, Component, S Video, Composite. You can go from one level to another which is one above or below, but cannot jump two levels.
As one example, if you want to utilize the HD capabilities of the Cinego, and you have HD cable or satellite and also a BlueRay disc player, such as a Playstation 3, you connect your HD cable/satellite and the PS3 each to a switching device, and connect the switching device output to the component input on the Cinego. The switching device, if you buy an automatic one, will detect whether the cable box or PS3 is on, and will transmit that signal to your Cinego. You may have to use an HDMI to Component conversion cable, or your switching device may have the ability to input HDMI but output the Component. The Cinego can only input the Component, as it doesn't have the HDMI input connector. The auto switiching device is about $25 and is available at big box retailers such as WalMart. So are the cables available there.
Apr 20, 2009 | Radio Shack Cinego D-1000 Multimedia...
Canon LV-S2 projector not work with component signal input
Try unplugging the projector. This seemingly works but I can't figure out WHY....
Mar 18, 2009 | Canon LV-S2 Multimedia Projector
We have a Toshiba TP50H95/TP55H95 Color Stream Projection TV that is 10 years old and we recently switched cable companies. Since then the picture is not filling the screen completely on bottom or on top...
A to expensive to fix part is going on the projector. Suggest you get a new one. I've owned 3 projectors over the years. The best one is a Viewsonic 7820hd. 3000 to 3200 lums brightness, short throw lens (104" screen at 12 feet from the projector) 1 HDMI input 1 RCA input 1RGB input and 2 computer inputs. Price varies- but I got mine at Tiger Direct 3 yrs ago for $488 bucks- the Viewsonic 7822 (2 HDMI inputs) is on the Viewsonic website on clearance or refurbushed for around that price. AND- They do a full 1080 HD and also 3D.
Jun 02, 2017 | Televison & Video
Video input not recognized
Will it work if you change the input to manual and select the correct imput source?
Mar 18, 2008 | Hitachi CP-X275 Multimedia Projector
PLV-Z2 AV System Menu locked on 1080i
If I understand your description correctly, when comparing it with my Z2, this is a function of the input type. If you have the input set to DVI and ANY digital source connected, the projector selects the mode that it is receiving and does not allow you to modify it. The options on this menu are only available when using an analog input. Try switching to any of the analog inputs and see if the option doesn't re-appear. It seemed strange to me too at first, but it makes sense because the digital input does not require "fine tuning" to convert it from analog to digital because it is already digital and therefore the signal itself skips this conversion step and the menu that goes with it.
Feb 25, 2008 | Sanyo PLV-Z2 Multimedia Projector
Hitachi PJTX100 Multimedia Projector Logo
56 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
