FixYa.com
Tags:
IBM 9516 Monitor
No clear picture just wavy lines and error message
posted by dalawr30 on Nov 26, 2007
I get an "Unsupported Video in red and VETICAL FREQ: 60 Hz with the entire screen wavy line is blue rising to the top. The monitor works ok on older OS's. I am running XP Pro. How do I set this so that it will work? I have tried using a different monitor and checked the Hz frequesncy. It is set at 60.
Comment by dalawr30, posted on Nov 26, 2007
Also was able to get it top come on by using the F8 upon boot up and enabling VGA, but it would not retain the stting there. Your solution retained the setting. Thank You.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
tomj23
Rank:Guru Guru
Rating: 86%, 1525 votes
The spec sheet I found says your monitor should be able to display 1280 x 1024, 720 x 350, 720 x 400 and four other resolutions in the 640 x .... range which are pretty useless. Try setting ti to 1280 x 1024 at 16 million colors @ 60 Hz and let us know what happens.
Rating Locked! (?) dalawr30 has rated this solution as FixYa!
Can you Help with these Monitors problems?
Monitors
monitor problems
please give me circuit diagram... Answer This...
Monitors
15 inch onitor amsung
"Control Lock" sign... Answer This...
Monitors
monitor stops display
My ViewSonic TFT monitor stops... Answer This...
Monitors
mitsubishi nxm56lcd monitor
Powers up and is black or very... Answer This...
Monitors
MAG Innovision monitor
The bottom left of the monitor... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
