Question about Maytag Washing Machines
My maytag neptune dryer keeps blowing the thermal fuse
Maytag neptune model #MDE9700AYW
    Sergeant:
  • 261 Answers
Overheating is almost always an airflow problem. Check airway before the place the fuse is located and the vent pipe and vent after the fuse to make sure they are open, If the airway is clear, the thermostat may be allowing the heating element to stay turned on until the dryer gets too hot,
Posted on Sep 29, 2018
  • Maytag Master
  • 2,573 Answers
Make sure air duct inside dryer and also going outside is clear. Make sure heating element is not grounded to housing.
Controlfrk
  • 304 Answers
SOURCE: Maytag MDE9700AYW electric dryer doesn't stop in sensor dry mode.
The link below contains the service manual. Detailed Troubleshooting begins on page 10.
Good luck
MDE9700 Service Manual
Posted on Sep 22, 2009
SOURCE: Maytag Neptune Thermal Fuse Location?
Yes, I just changed thermal fuse on the same model . . . take off the front door, the front panel and there it is; attached to the vent tube with a flimsy bracket
Posted on Oct 08, 2010
SOURCE: how do you replace the
I am about to find out! But according to Tim Mereno, which by the way sells the part for 65. said it is not really to difficult! I will let you know.
Posted on Jun 20, 2011
Macmarkus
  • 2605 Answers
SOURCE: Can anyone please tell me where the thermal fuse
Hello Tom, welcome to FixYa.
I'll start by saying your post indicates it is a Maytag MDE9700AYW dryer. I'm not sure if you know this, but this particular Maytag is built by Samsung.
To address your question as to where the thermal fuse is located on your dryer, it is one the heater housing, there is a hi-limit and a thermal fuse. If the Thermal fuse/safety is gone, replace the hi-limit as well.
Here is a chart to identify which thermostat is which and it's location, the resitance value to check for and part number for replacement.
Once you've gain access to them you'll need to remove at least one wire to check the continuity...the values are shown in the above chart (basically it's either open or closed)
As far as part, there are a couple of places I prefer, on-line at "searspartsdirect.com" or "repairclinic.com".
**unplug the appliance and turn off the gas supply before attempting any service...safety first**
Let me know how you make out or if you require further assistance and I'll do whatever I can. Good luck.
Regards,
Macmarkus :)
Posted on Sep 02, 2011
  • 433 Answers
SOURCE: maytag electric dryer thermal fuse keeps blowing, what could be the cause
Check the dryer vent for obstructions
Posted on Dec 18, 2012
Maytag mde9700ayw thermal fuse on heater box blew. replaced it and blew again. will an open safety thermistat cause this
No. A short in the heating element is more likely to blow the thermal fuse. If the thermostat was open, there would be no power applied to the element
May 15, 2017 | Maytag Dryers
Where is the thermal fuse located
The thermal for the entire dryer is on the blower housing and the one for just the heater is on the heater case.
Jan 12, 2016 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag neptune error code
anytime a fuse trips it is due to too much load on a circuit-or over heating-tear down the machine and clean out lint look for it in the ducts that exhausts out of the house and even the outside flap-cheers Denny
Oct 22, 2013 | Maytag MDE9700AYW Neptune 174 Electric...
My dryer keeps blowing the thermal fuse help
Check your lint filter, exhaust duct, and check if duct flapper is opening fully or not. Allow some time between loads and don't stuff too many clothes.
May 12, 2012 | Maytag MDE9700AYW Neptune 174 Electric...
Can anyone please tell me where the thermal fuse is located for a Maytag Neptune MDE9700AYW
Regards,
Macmarkus :)
Sep 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
THE DRYER IS NOT PUTTING ANY HEAT OUT.
ften a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Jan 22, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Hi, my Maytag Neptune gas dryer will not heat up anymore. When the machine start to run, you can hear the gas is burning & the heat is blowing from hot to warm to cold in about 60 to 90 seconds that is...
The thermal fuse is NEVER at fault, it is only a symptom of some other problem and is a serious safety warning. Check that the exhaust vent is clean and not kinked or otherwise obstructed. When WAS the last time you cleaned the vent??
Sep 16, 2017 | Maytag MDE9700AYW Neptune 174 Electric...
Good luck
Sep 22, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Dyer model # MDE9700AYW wont heat it blows cold air
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
Apr 07, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Mar 30, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Washing Machines Logo
184 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
