Question about Maytag Washing Machines
How can I DIY maintain my Maytag washing machine
  • Maytag Master
  • 2,425 Answers
Depends on design and model
Posted on Sep 28, 2018
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
I have a Maytag Neptune TL ( Model # FAV6800AWW) washing machine does spend but clothes still soak after it done. when you spend it by hand, it only spend in counterclockwise.
Any error codes. What happens if you start a Spin Only Cycle witht the same load? Does the times stay stuck at xx minutes in the LED display and the machine constantely starts and stops?
The more info on your problem the better.
Do you want to DIY the fix? Google this; Neptune TL Washer FAV6800AWW see the 5th post down here for general info and the Service Manual. If you want to try to DIY the repair I will help.
Apr 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My 6 year old Maytag Neptune TL washer just started getting stuck at minute number 33, not continuing its cycle. I've unplugged the machine and restarted another wash only to have the same problem. Is...
Frank,
Tried to work with an owner of a Series 16 machine recently.
I discovered this with very painful guidance in troubleshooting that the Clutch Pulley was was seized up I feel do to a Leaky Tub Seal.
If and only if you have basic DIY skills you can work toward saving your $1k machine. I can help the DIY owner if you have the concept of pounding out bearings and pounding them in, read this post [FIXED] Maytag Neptune, Timer Problem
This is the forum to DIY the repair in. You can get the Service Manual from this forum and I'm writing supports notes that are a general guide line to do an Outer Tub Rebuild for around $170 if you control the parts buy cost correctly.
See this post for what is involved for a Outer Tub rebuild.
FAV6800A/FAV9800A Outer Tub bearing replacement
Mar 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washing machine keeps saying DC on the screen and will not drain all the way unless I take all of the clothes out. It is also leaking all over the floor.
Rose you have some issue here. The DC error code more than likely is from a failed Clutch Pulley possibly brought on by failed Tub Seal or Drain Line leak/cracked drain pump Drain Line hose leak from Sump Cap to Drain Pump. Possibly brought on byl the unbalance issue caused by the Clutch Pulley lot of wash tub banging around in Spin Cycle correct?
The average DIY'er can repair comes down to down time and how much you can tolerate before you junk a $1000 machine.
If you want to DIY I will try to help this forum makes the DIY help process very difficult. This forum makes it extremely difficult to find previous post. There is no effective search engine or Sticky post in this forum. IMHO this is not a true DIY forum.
If you want to DIY the issue Google "Sticky: Neptune TL Washer FAV6800AWW" you can get the Service Manual from that site to help you DIY the fix along with forum guidance.
Post in the Maytag/Magic Chef/Admiral/Jenn-Air
Feb 02, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washing machine is leaking water during wash cycle
If your going to DIY the fix or at least ID the leak source you will need to remove the fron cover off the machine. Power down the machine and follow the front panel removal process in this Clutch fix post.
If you need additional help Google "washer repair forum" and choose any of the Appliance Repair forums that you hit. Post your model number and I will help you out. If you don't have the FAV6800A/FAV9800A Service Manual I can help you with that at a true DIY Appliance Repair Forum.
I have stopped supporting this forum to many issue with posting support pics and directions at this site. This site it is not a in my opinion a true DIY site for owners.........Rich
Nov 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Makes screaming noise while washing. MAV7200. Belt or Bearing? Fixable by DIY?
MY MAYTAG WASHER IS MAKING A NOSIE WHILE WASHING A GRINDING NOISE DON'T KNOW IF IT THE BELT OR BEARING? WHAT DO I NEED TO DO?
Jul 20, 2010 | Maytag MAV7200 Top Load Washer
My maytag neptune top loading washing machine when washing sounds like there are belts squealing and the washer tub seems to hit the sides of the machine when spinning what is going on?
This sounds like a possible Clutch issue. Is the machine model an FAV6800A or FAV9800A?
When the washer is banging around do you take unbalance errors such as dC or uC?
Do you want to DIY the fix or call in a repair service. If you could confirm your machine model number......Rich
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Keeps flashing DC will not finish cycle?
Hello jernlyn,
If your machine is A FAV6800A or FAV9800A most times this is a Clutch malfunction. Dose a Spin Only Cycle complete with no clothes in the wash Basket?
If your machine is one of the above I can help you DIY the repair. See this Clutch Fix Post . Most DIY folks can perform and I will help you with any questions or concerns. If you decide to DIY what are the 1st two digits of your serial number? They will 10 thru 17.....Rich
Feb 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Black mold on rubber seal
youust replace it, and start from scratch. From day one you have to maintain the boot with Affresh, whipe out water
Nov 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
182 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
