Question about Panasonic PT-51HX41 51" Rear Projection Television
Help pt-51hx41e I have a wavy line on the bottom 1/3rd of the screen. is this something i can just replace a part to fix?thank you for your time.joel
  • robnnc Jul 27, 2008
    I have wavy lines on most of my screen. Does the same solution apply? Also are the other two capacitors 3300mf 35v as well? Any trick to replacing capacitors...drain electricity etc?
  • 934 Answers
Joel,
The likely common problem that causes that symptom are three electrolytic capacitors. C840 is a 3300mf/35v and the ohter two C762 & C836 are somethimes questionable so you may want to measure them first with an ESR meter.
If you locate and replace them let me know how it turns out...
Bill
Posted on Nov 26, 2007
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT 51HX41E flickering colors
ok her is a good test for u, bring up the pip on screen and see if the picture is the same as the main picture ok.now if at is it sounds like to me that u have a bad pip board that is causeing your problem u can bypass the pip u just need to jump the video in to the video out and sync out and in and remove the pip most of time i have found that the small caps go back on the board and u lose snyc and that is y your picture goes black and white with blinking color in the background. now the stk392-150 is a better chip then what u had in it but convergence problem has nothing to do with color snyc. i hope this will hp u marty
Sep 18, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Help problems with Panasonic PT-47WX49
Can you post a picture of what your screen looks like and I will try an assist you with the problem.
Aug 09, 2008 | Panasonic PT-47WX49 47" Rear Projection...
My panasonic pt-51hx41e will turn on for couple secs then turn off
hello. it sound like a power supply problem.!!! to me .!!! you can check it frist.!!!"good luck"
Aug 01, 2008 | Panasonic PT-51HX41 51" Rear Projection...
PANASONIC PT-51HX41E
The convergence amps have most likely failed. That unit takes two STK392-110 (Sanyo) amps. For more reliability I'd have them changed using an STK392-150. They have a greater amperage and higher heat tolerance.
It's clearly a job that you want a qualified shop to do.. Call around and get some off-the-cuff estimates on what they charge to change out the convergence amps and tell them that you would prefer they use the 150's instead of the 110's.. They'll probably wonder how qualified you are. :)
Bill
Nov 13, 2007 | Panasonic PT-51HX41 51" Rear Projection...
PT-53TW53
Try to read this blog: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Apr 24, 2007 | Panasonic PT-53TW53 53" Rear Projection...
PT 47 convergence IC's? box? both?
Always suspect the IC's first, digital convergence prblems are actually pretty rare IC's go everyday. I'd check partsore .com Generics usually work fine, they are probably STK392-110's but check to make sure.
Apr 16, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Wavy horizontal picture
the vertical IC outpt needs to be replace
Dec 29, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Clean inside of the screen? Spider webs?
You should get the service manual so you dont take apart something you shouldnt
Aug 24, 2006 | Panasonic PT-61HX40 61" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
