Ts a fuser error and it has to be reset in service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
if the problem comes back there is a problem with the fuser but in my experiance resetting has worked 99% of the time
SOURCE: cannon image runner c6800 error code E000001-0003
Its a fuser error and it has to be reset in service mode
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose CLEAR
then choose ERROR
then press OK
SOURCE: E000
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
Here's the definitive reset procedure
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
please rate my answer after trying if satisfied
SOURCE: Cannon image runner 2200 error code E000002-0000,
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom
E002/E000/E003/E261/E733: due to AC line noise.
Description
E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise.
Cause
When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times.
Field Remedy
Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise.
REMEDY
Caution
Press (* then 2 and 8 together then *)you are in service mode monitor:To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
SOURCE: cannon image runner 2200 Error code E000019-0000
Empty the waste toner container. From left side of copier you have small cover with one screw.Remove the cover and empty the container and clean it very well, you may use alcohol for the neck of the bottle to ged rid of of antistatics.
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
